#66119 07/13/02 02:57 AM
Kyo Offline OP
Hi,
Please excuse my poor use of english, as it's not my native language...
Yesterday I changed both spark plugs and wiring on my '97 Mystique. Wires were cracked and the plugs were way overdue!
After restarting the engine, the Check Engine Light came on - so I pulled fused #4 and #11 to reset it, and it came back on as soon as I restarted the engine a few minutes later.
After going over the parts I touched, I noticed a broken connector, on the right side of the coil pack. It's a 2-wire connector, leading to a black box just underneath the coil pack. I don't know where it's supposed to be plugged in!
The wires are about 7-9 inches long, under a plastic sleeve. The female part is broken, so all I have is wires leading to both male and female connector parts, and the two "forks" that are probably part of something else I can't see...
The wires going to that connector are green on black and black on green (I hope my yellowish flashlight didn't set me wrong).
I have a feeling that this connector is the source of my problems - anyone knows where it's supposed to be going? I'm suspecting a sensor of some kind, the absense of which would trigger the CEL..
If I can't find help here, it's off to the dealer, unless I can find a neighbor with a Duratec Contique in the driveway!! smile
Thanks in advance for any information ...
Kyo
97 Mystique
ATX Duratec
I LOOOVE IT!
H
H
The wire colours you describe indicate circuit for EGR vacuum regulator solenoid. This is the black plastic device with a round top, to the right of coil pack, mounted on intake manifold.
stock CD on LS, cass on LX
4 wheel discs on LX only
Kyo Offline OP
Hi again!
I've been able to repair everything this morning, thanks to you! The EGR vacuum regulator solenoid was easy to remove, and the connector was literally ripped off from behind of it. I've been able to glue it in place with industrial-grade glue - it should hold on for a while, more than enough for me to get a replacement part.
Now the CEL is gone, and engine purrs like a kitten.. smile
Thanks again!
Kyo
97 Mystique
ATX Duratec
I LOOOVE IT!
H
H
You're welcome. Glad to hear your back in business.
Kyo, your english is great. No worries about that!
Glad you got your problem solved too.
Kerry
99 SVT Contour Silver Frost, #365/2760
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
