Ah Rick, what do you know about changing engines anyway? Think you're some sort of guru or something?
To pull your engine from the top side, you basically do like any other engine pull (drain fluids, remove mounts, unplug harness at the ECU, etc) with only a few additions...
Pull the driver's and passenger's side hub assemblies from the lower control arm ball joints. Remove the passenger's side axle extension from the carrier bearing end (the hub end can stay connected) by swinging the hub carrier/strut assembly out of the way. Remove the driver's side axle nut, then swing the hub/strut assembly out of the way, releasing the axle. Put a wire clothes hanger around the end of the axle in such a way that it will hold the CV joint together... Do not pull on the CV joint or let it dangle because it WILL separate. Pretty much, that's the only "special" item needed...
Pull the engine/trans as one unit. I tried it engine only and it doesn't work good at all...
