Well since you are replacing the water pump, you might as wel replace the coolant hoses before they fail, and it will save you time later on, put in all new coolant, repalce the timing belt because that is supposed to be done every 60,000 miles, also the tensior spring, because if that things locks up, everything that the timing belt controls camshaft/crcnkshaft, alternator, water pump controls will lock up and the valves will hit the pistons and they will be bent it is bye bye Contour.
