testing the dimmer rotary switch:
The dimmer is actually a POT (variable resistor.
If you remove the front dash panel (the one the dimmer is on, you should be able to access it.
Removing that panel shouldn't be too hard.
Once you have access to the POT, you can see there will be three posts, most likely in a triangle shape. The Center one will be what leads to your instrument panels.. you could try jumping the voltage by shorting that post to the post that your +12V is located on..
(wow.. re-read that, it is confusing..).. use metal (insulate yourself.. lol) and short across the two posts, one that has +12V, the other that leads to your panel.. and the voltage should thereby skip the POT... if your panel comes on, then your POT is bad.. if not.. start looking elsewhere..
Word of mention: this is a rather radical troubleshooting method, when considering the dismantling of the panels, etc, especially if you haven't checked the under hood fuses yet..
HTH
As always, I stand ready to be corrected..
Ray
