Posts: 1,360 |
i use autolite platinums (or doubles i cant remember which at the moment)... i should have said i check them every 10K just because, last 10K i didnt change them cuz it was almost all highway miles. i just drove the thing from alaska to texas...about 9.8K when all was said and done...and yes i stopped in utah for an oil change.
Posts: 295 |
Mine's a '96 GL, Zetec, MTX.
Mine has just shy of 200,000 miles on it (198,xxx).
No major repairs whatsoever.
My mom had the car before I did, and took terrible care of it. She had the oil changed every 30,000 miles or so, don't think she ever changed the air filter, don't recall plugs or wires ever changed. Since I've had it (193,xxx), the oil has been changed every 2,000 miles (I'll drop this back to 3,000 soon), plugs and wires were changed, and air filter was changed (before I put an intake on it).
Hope this helps- -Jonathan
Jonathan
'96 Contour Zetec MTX
208,XXX miles
Posts: 350 |
I have a 96 Contour GL ATX Zetec Currently has 122,356 miles Major/Minor Repairs since 78k / Timing Belt, Waterpump, Alternator, O2-Sensors, Struts, Left side axle shaft, L/R Wheele Bearings, L/R outer tie rod ends, L/R Lower Ball Joints. All Hoses and Belts. Some of these things are general maintence items that any car owner should replace as the miles get high. In addition to the above, I have provided regular oil changes with Mobile 1 every 3k as well as plugs and wires as needed, and other maintenence such as antifreeze flushes, ATX changes, TB and MAF cleaning. I try to fix problems as soon as they start, and I do most of the work my self.
Posts: 403 |
Listen to me now and hear me later (Han's & Fran's, or, Governor Arnold, take your pick).
I must be one of the most blessed guys WRT high mileage vehicles. I have almost 144,000 miles on my 96 Contour Sport 2L. I have nearly everything original. This includes engine, trans, fuel pump, water pump, alternator, and compressor, EGR system, coil pack, cats.
The things that have been changed are rotors, link pins, belt & tensioner, IAC, battery, plugs & wires, wheel bearings, tires, pads. Thats all I can think of although there could be a few more.
Don't even ask how many miles are on my Bronco II (225,500).
96 Sport 2.0L - 190,XXX miles
Posts: 2,100 |
I am doing pretty good.
1. 2000 SE sport V6 MTX
2. About 115,000 miles
3. Alternator replaced at about 113,500 miles or so. Only other things done are new brakes pads all around at 100,000 miles and new front rotors at 100,000 miles. and I have gone thru some tires
4. In some things I am good (oil changes) and in other things I forget distracted and never get around to them.
Beaten - 2003 MazdaSpeed Protege 29K <- broken hearted
Daily/Weekend Beater - 1990 miata 138K - AutoX every weekend = Adult driven on weekends
Posts: 288 |
95 Contour GL 2.0L I4 ATX Recieved in 96 with 20K and change, now has 51K and change
Major repairs:
Spark plugs rusted out for some reason causing 2 cylinders to mis fire. Needed new spark plugs, wires, coilpack. $300 bucks. (got hosed huh.)
Ac problem around 35K, not blowing out vents. Needed vacuum hose re-attachment.
Recently rear tire lost tread, knocked off bumper. Got 4 new tires, took 5 minute epoxy and glued bumper back on. Looks new except for paint cracks from tread smacking bumper.
Needs:
New timing belt, tensioner pulley
New oxygen sensor
New struts in back, and whatever is in the front.
Condition:
I take really good care of it. I also dont drive it much. everything is really close to me. Their opening a new sav-ons by my house. So i have my college across the street from me (walk), now sav-ons (can walk), a new 7-11 (walk), local internet cafe (walk). All i need is a blockbuster and id be all set.
-Rob
White 95 GL ATX
56K Miles on it.
Optilux By Hella Fog lights (The Angel Eyes)
Driven hard, Just like I like it!
Posts: 2 |
1) 95, GL, Duractech 2.5L, 5 speed manual. 2) 182,218 - all highway. 3) No repairs to engine or drivetrain. 4) Changed oil/filter faithfully every 3K. I just sold the above and bought a 98 SE Sport. I've been really pleased with the Contour overall but have suffered some of the usual things (water pump, front wheel bearings, blah, blah). The 95 was still going strong, but it was time to trade up...love the leather and CD player
Posts: 392 |
1998 SVT Contour: 142,xxx miles Replaced plugs, wires, fpu, alternator, starter, clutch and transmission. Transmission was broke by drag racing at about 141,000 miles. Two O2 sensors went out at 141,000 miles also. Third O2 sensor went out at 142,xxx miles. Most parts on this car are new or modded. I hope to make it to 200,000 on the motor. The person that had the car before me put 138,000 mostly interstate miles on the car.
1998 SVT
Posts: 5,621 |
Zetec, ATX, 1999 (bought in November '98) - 105,000 miles - nothing major/minor - knock, knock, knock on da wood.
Posts: 328 |
It's not a contour but it's a ford! 1994 Ranger, 2.3 Liter, 325K miles, never rebuilt and still runs good!
1999 CSVT-Black 15.8@89mph
Driver for hire. PM me.
