to all ceg's my promblem is fixed the trans switch that sits on top of trans was the promblem some where inside the switch was bad had a new one put on and my contour is touring again. thanks for all your help also change my fuel filter and she's running like new so any one having a promblem with the tranny jerking or blinking od (overdrive lite ) its most likely the trans switch located right under the air intake hose i will keep you all updated thanks again this website is very helpful through my situation
