Posts: 192 |
whats the cheapest place online that you guys have found complete air cylinder setups at?
cause i wanna compare to a deal an indiviual says hes giving me...
Posts: 132 |
First off i don't think you want air cylinders. They ride like [censored]. You are going to want air struts. I am looking for some myself and i found them at aim. Here is the link Ford contour struts . They are about 1500 for a complete set with a crapy compressor. If you drive alot you should upgrade your air compressor to something more heavy duty. They have kits but you still have to buy the size of air line and valves and so on seperate. Like i said a total package is about 1500 but you still need that new compressor. At least i recomend it. When are you thinking about buying them. I guess they take stock contour struts and modify a air bag bracket for the bag to sit on. I would recomend a rear sway bar to help keep good handling. I hope i helped.
Posts: 192 |
well i dont drive a contour i drive an escort i am swapping the contour into my escort at the present time, and we wann go ahead and do our suspension while the engine is out of the car.....heres the deal i ran across
"Air Cylinders custom fitted for Ford Escort ZX2 with pre-wired 10 switch clear box, two dual cylinder gauges and everything needed to run the system (EXCEPTION: DOES NOT INCLUDE THE HOSES) and an extra smaller air tank - Over $2000 worth of parts, I want $1200 plus shipping "
Posts: 773 |
yea, www.truckn-store.com is pretty good for airride stuff. ur gonna need strut bags, not cyliners and accumulators. airline is very cheap. figure about $30 for 100ft of teflon 3/8 airline. make sure you get quality brass fittings, not those crappy plastic ones. get at least a 6gal tank, or even a few smaller ones to equal 6+ gallons, and a 3/4hp 100% duty compressor. the strutbags alone will cost about $1,000 usually, and the rest of the stuff with install will bring your total to a lil over $2k probably. check my page out for details of my setup.... http://www.deanjoyce.com/mystique/index.htm
Posts: 192 |
so is 1200 for everything but hoses, a good deal?
Posts: 192 |
Posts: 8,143 |
i've heard before on NECO that you could do air cylinders on the rears but not on the fronts because they'll break.
Posts: 2,369 |
I got an offer for about 1800 shipped for all the things Dean said i needed. they are 2 3 gallon tanks though.
98 Lime Green SE w/SVT Kit, Projectors, CF Hood, 18" Rims, GC's, Shaved, System
98.5 Silver SVT #5737 Black FSVT Rims, MSDS, BAT Drop
85 Toyota PU Lifted
06 GSX R 600 Black/Silver
My Rides
Posts: 180 |
98 svt
Posts: 192 |
what up playa, the pimp is here
