Posts: 71 |
So when I step on the breaks at high speeds I'm starting to get shaking of my steering wheel. I need to replace my front breaks and rotors.
My thought is should I go with stock SVT rotors? Should I go with slotted, cross drilled, or maybe even both?
Anyone able to give feedback on these would be great. I'm not looking for people to give opinions on these when they don't have them on their CSVT. I'm looking for people with any type of slotted or cross drilled on their contour to tell me whether they like'em/hate'em what ever.
thanks!
'98 SVT E0 Silver
-TRENDWHORE!
Selling out never felt so good!
Posts: 4,693 |
There has been a lot of posts about slotted and drilled rotors. I'm sure that you will get more opinions than mine but here is my $.02 worth.
Slotted and / or drilled rotors don't really do much of anything to help the car stop faster. They are more likely to crack as witnessed by many racers.
In my opinion, don't get slotted and / or drilled rotors unless you just want it for looks. And they do look good.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 331 |
I'm in the process of installing new rotors and pads on my tour. I went with the SVT brakes on the front. I'll know more on the difference tommorow when I'm done installing. Some jerk stripped the star bolts on the rear calipers. I spent 2 hours trying to remove them with some help. I can send you pictures when I done to give you an idea.
Posts: 331 |
Posts: 1,254 |
Literally, just got done putting rotors and pads on mine. V6 SE. baught TRW rotors and TRW Pro-series pads on the rear. SVT rotors on front w/same TRW pads. WONDERS!!! dont waste the money on drilled or slotted my.02
Posts: 331 |
Cross drilled respond very nice. My brakes run 100% cooler and brake so much better. Check out the pics of the finished job. linky
Posts: 1,254 |
very sweet. i know their job is to cool the brakes. but for our everyday driving cars, (in my opinon) is not worth the moolah. with all new brakes and rotors, the rotors being blank, it is a much improved braking system, even though its mostly stock.
Posts: 331 |
It's the stock rotor size on the SVT's. That makes for a very good increase in braking power from the stock 96 contour with 4 wheel disk.
Posts: 3,867 |
Originally posted by mycainsbroken: i know their job is to cool the brakes.
The point of holes in the rotors is not now, nor has it ever been, to "cool the brakes," but to expel gas released from the brake pad at extremely high temperatures--a phenomenon known as "outgassing." A bit of heat sink mass (cooling efficiency) is sacrificed to solve a very specific problem encountered by race cars on track. (Everything is a compromise.)
The other thing sacrificed is pad and rotor longevity. But, hey, as long as it gets us through this race, and saves us a few tenths per lap, it's worth it, right?
With modern pad materials, outgassing is less of a problem, even for race teams, and crossdrilling has proven to be less than optimum. Slotting achieves the same gas management objective, helps keep pads "clean," and offers less risk of rotor cracking. Still, when you look at most race series, the cars typically run either smooth-faced or slotted rotors.
Function before fashion.
'96 Contour SE
Posts: 383 |
Originally posted by Contour_LXsport: My brakes run 100% cooler linky
How'd you measure that?
Pacific Green '96 Contour LX V6
â??98 GTP, light mods, 14.66/94
Calypso Green '92 Mustang LX coupe, 13.56/101
Crown Autocross Club 1999 Street Tire Champion, 2000/2001/2002 Street Modified Champion
KCR SCCA 2002 Solo II Street Modified Champion
