Smurfette
Smurfette
Posts: 8,770 |
95 Contour GL 2.0L - pretty sure the previous owner had the fuel tank recall done.
I've noticed for the past couple months that when I fill up with gas, the fuel gauge takes longer than normal to move to Full. I've done a bunch of searching both here and in the archives and didn't see anyone that had a similar problem (most people had erratic readings on the way down to empty and not the other way around).
I recently replaced the fuel filter (figured it was probably due for that anyway) to see if that'd change things, but I'm still having the problem. I also took the gauge cluster off to see if there were any noticable problems with the gauge. None that I could see, the needle moved smoothly, but the problem still exists.
I noticed in those other threads that fuel sending unit was recommended as the required fix.
Any ideas on what my problem could be?
Kim
1995 Contour GL
Needs less "needs more"
Posts: 11 |
'99 Contour SE Sport V6, 5spd, Dark Blue / Blue
Smurfette
Smurfette
Posts: 8,770 |
I think from the time I start the car, let it warm up, and then drive about a mile, the gauge finally reads what it should read. It's a snail's pace.
Kim
1995 Contour GL
Posts: 4,714 |
I don't know if its similar, but I've noticed a "delay" in my gauge (on the Sport). For example, I'll happen to notice its at 1/2 tank on my way home from work. Park the car, and its still at 1/2 tank. Later, I'll get in and start it up and all of a sudden it'll drop 1/8 of a tank. It'll hold there until I stop and restart, then it will drop again. Is this like what you're experiencing?
On long trips the needle will gradually drop like it should; this only seems to happen on short trips. I haven't complained only because its really not a problem for me. I hardly ever let it fall below 1/4 tank.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Smurfette
Smurfette
Posts: 8,770 |
it always goes down the appropriate amount during use (well when it finally finds its way up to where it should be), so I only seem to have problems after filling the tank and each startup afterward.
Kim
1995 Contour GL
Posts: 1,145 |
Originally posted by hetfield: I don't know if its similar, but I've noticed a "delay" in my gauge (on the Sport). For example, I'll happen to notice its at 1/2 tank on my way home from work. Park the car, and its still at 1/2 tank. Later, I'll get in and start it up and all of a sudden it'll drop 1/8 of a tank. It'll hold there until I stop and restart, then it will drop again. Is this like what you're experiencing?
i have something like your expeirencing it take for ever to go down but it goes up fine also when i get about 125 miles on it it starts to drop faster after that and the mileage goes way down because if i fill it up with 3/4 a tank the mileage is like 25 if the tank is 1/4 or below its like 18 and that really sucks as i am a college student
98.5 Black SE ATX
Smurfette
Smurfette
Posts: 8,770 |
these are the problems that were mentioned in the search I did of the forums here and the archives. For this problem, people were suggesting there was a problem with the fuel sending unit.
Kim
1995 Contour GL
