#65840 07/10/02 07:10 PM
I only notice it when sitting still or backing out of my driveway, but when I apply the brake pedal, there is a relatively loud metallic clicking noise that comes from the rear brakes. I can't tell if it's only on one side or both, but I'm hoping that it's nothing serious (wife drives the car back and forth to work every day). Maybe a loose caliper or something? Maybe just noisy linings? Any thoughts or technical advice would be much appreciated. 199 Contour SE Sport V6 MTX.
'99 Contour SE V6 w/MTX (Black Clearcoat)
'02 Dakota 4.7L V8 2WD X-Cab (Flame Red Clearcoat)
#65841 07/10/02 08:55 PM
The noise you mention doesn't sound familiar, especially if you have rear disk brakes. I would get the pads checked out asap which may be very worn and loose in the caliper. (causing the noise??) Rear pads can be changed in about 20 minutes, although you'll probably also want to get the rotors turned. ($8-$10/side) My rear pads lasted for well over 50K and still had plenty of wear left on them when I replaced them. If you say the rear brakes make noise when sitting still, I guess that's if you push on the brake. How about the hand brake? (Shouid make same noise) Sounds like something is loose, or possibly cracked?
Scott
#65842 07/11/02 01:40 PM
I'll have to test the hand brake part to make sure it duplicates itself. If it's not that, then I don't know exactly what to think.
