Yeah, your stock water pump is due to go, the plastic impeller breaks up. Aftermarket waterpumps with metal impellers are available. Mine went before 60K. You also might have to find a friend to help you with install of the aftermarket y pipe, some shops do not touch them until 80K because of federal emissions laws.
And remeber to reset your PCM after you do a few of these mods, by doing battery or fuse disconnects for 10 to 20 minutes or so. Then you WILL feel and hear the difference after a couple mods like you're starting on.
MSDS, SHO-shop Y, custom 2.5" catback; xcal2; 63mm TB, K&N 3530; Koni struts, Aussie bar; THaines forks, Quaife, SpecII, UR fly; DMD; Nima UD pullies; Stazi brakes; f&r Pole120 mounts. Just a daily commuter car. Silver '98 SVT E0 #3159
