#65828 07/10/02 06:39 PM
E
E Offline OP
E
I have a 95 contour GL ATX with the zetec. I was wondering if anyone can help me with this problem... when the car is in drive and you are stopped it shakes really bad, it gets like 10x's worse when the a/c is on. The vibration goes aways once you start driving. I've had it looked at by a few mechanics and they seem to think its the motor mounts. I replaced the passenger hydraulic mount and the front mount and still no luck! Also found the belt tensioner was busted up. Replaced that. It got a little better. What the hell could it be? Should i replace the rear mount and the tranny mount??? Someone suggested it could be a bad harmonic balancer...
95 Contour GL Zetec
New 16" Focus wheels! (look better on contours!)
APC Plasma white high and low beams w/ upgraded wiring harness
Pilot Hyper white fog lights
Cold air intake
Optima battery
APC billet antenna
Sony Cd Player w/ jensen subs
Green neon pedals
Green strobes for reverse lights
Ventvisors
20% mirror tint all around
Custom grille
Aftermarket keyless entry
Remote car starter (very usefull)
#65829 07/10/02 06:59 PM
E
E Offline OP
E
hello? anyone???
95 Contour GL Zetec
Cold air intake
Optima battery
APC billet antenna
Green neon pedals
Ventvisors
Custom grille
#65830 07/10/02 07:53 PM
E
E Offline OP
E
helloooooooooooooooooooooooooo?
95 Contour GL Zetec
Cold air intake
Optima battery
APC billet antenna
Green neon pedals
Ventvisors
Custom grille
#65831 07/10/02 08:55 PM
Try the other motor mount, what have you got to lose? Also, how about a tune-up, plug wires, etc.
Dan B.
#65832 07/10/02 10:51 PM
I seem to remember the idler pulley on the Zetec being a fairly common item to wear out and give the symptoms you mention. Might want to try searcing the zetec forum or post there if you don't find anything. (Look for pulley)
Scott
#65833 07/11/02 12:11 AM
E
E Offline OP
E
Thanks for the advice... I think replacing the other mounts is what i'm gonna have to do cause the vibration is so annoying and I don't know what else to do. As far as a tune-up, I did one like 2 or 3 months ago... a complete tune up at that. Funny thing I just remembered, the salesman who sold me the car told me that ALL contours shake and vibrate. I didn't believe his lying ass but I wanted the car anyway. Anyone else have the same problem i'm having?
95 Contour GL Zetec
Cold air intake
Optima battery
APC billet antenna
Green neon pedals
Ventvisors
Custom grille
#65834 07/11/02 04:50 AM
Red Offline
I have been working on my wife's 96 gl for the
last four months.
To date I have replaced:
all four motor mounts
plugs
plug wires
iac valve
water pump
accy belt (twice)
idler pully
Got to looking this afternoon and I think the tension pully is weak.
I think that about covers it.
Did I leave anything out....don't think so.
Black 96 gl
mostly unchanged
except for the urge to have it crushed
#65835 07/11/02 05:13 AM
96 Gl and I also have the exact same problem.let us know if you get it fixed so I can fix mine.
#65836 07/11/02 06:51 PM
Mine shakes too and it's nerve racking! I need to know what'll fix it as well.
"If you got it, you got it. If you don't, you won't. And if you don't use it, you lose it."
