#65823 07/10/02 06:30 PM
JHAT Offline OP
Got new tires a while back. Hear a clicking noice coming from driver rear as if sonething is slapping the ground as the tire turns. Unfortunately I don't live near where I had the tire put on. Any thoughts?
#65824 07/10/02 06:44 PM
Look for a rock in the tire's tread! wink
Run your hand over the tread and then if you can't find any rocks, move the car ahead just a little and check again.
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
#65825 07/10/02 06:46 PM
Brake hose hitting an 'inside' wheel weight.............
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
#65826 07/10/02 06:55 PM
This is weird, I noticed a couple days ago that I'm having the same problem. A clicking/ticking noise coming from the driverside rear. I haven't jacked the car up to look, but doesn't sound too serious.
Tim
'00 SVT
#65827 07/10/02 07:00 PM
JHAT Offline OP
Yeah nothing serious. Runs ok. No rock. Just a ticking. Thinking when the tire was put back on something might have been knocked loose.
