Page 2 of 2 1 2
Originally posted by tw0wheelin:
The sticker essentially warns that the teflon (or whatever) coating can be easily scratched off. A soft cloth and TB cleaner won't hurt it anymore than hot exhuast gas from the EGR ports will. As mentioned the coating is not that effective anyway or we wouldn't have the EGR buildup probems many have experienced and cleaned up. I've not seen any faster buildup of gunk or ill effects from gently cleaning the TB and upper intake ports with TB cleaner. (Over 40K miles since initial cleaning...)
Oh, OK! laugh
I understand that you and several others have cleaned the TB with no problems afterwards but why the heck would the dealer not do the same?
Oh, wait, I know why, they make more money by replacing it instead of spraying some cleaner down there and wiping it off! :rolleyes:
Dealers=Stealers as if ye'all did not know! mad wink
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
Many dealers do clean the throttle body. They recognize that the teflon coating does cut down on the gunky build up, but doesn't really prevent it. Before Ford introduced the teflon coated throttle bodies, cleaning was even more essential. After they started the teflon treatment, Ford would no longer pay for cleaning under warranty.
Ford has also converted to DRI (Deposit Resistant Injectors). Before converting to DRI, injector cleaning was also more critical. They also claimed that cleaning injectors was no longer necessary. It did help, but they soon backed away from their attitude of "never needs it anymore".
As to what is causing your check engine light, it is all speculation until you read the codes and check it out. Literally hundreds of things can trigger a check engine light.
Jim Johnson
98 SVT
crank Offline OP
pulled codes and all is well. I don't know the codes oof hand, but it ends up the cooling fan or sensor was telling the computer that the fan was unoperable. Fan was checked and works fine. TAs always, thanks for the interesting discussions.
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
Originally posted by crank:
Sorry for double posting, but I also traded that 2001 cav with major dependability problems. I traded for a 2001 Mazda Protege SE. Anybody know of any good protege sites?? Thanks again.
YES !!!!
I have one !!!
Protege Club
I also bought a protege... very quick actually... I love the car also...
The site is kind of growing now... it is not as big as CEG... My name there is Zetec.. :rolleyes: :rolleyes:
They do have some good info...
** CT - USA **
* 96 Contour Gl 2.0
5 Speed Manual / Clarion CD Change
8" Subwoofer & Sony Amp (LOUD !!)
The Cleanest !!!
* 92 Mazda Protege
5 Speed Manual / 1.8
* 94 Yamaha Virago 535
(better than Viagra !!)
crank Offline OP
I'll try out the protege website, thanks!! Any idea what the diff. is between a P5, MP3 and 3rd gen. mazda. P5 is protege 5. What are the others??
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
leaving the gas cap off will throw a CEL. your contour should be a vacuum-operated system. it senses a vacuum leak and the CEL goes on.
1985 SVO: 4 cylinders, 5 gears, 20 PSI
1998 torredor red SVT contour: #3705 of 6535
need info on your SVTs service/recall/warranty history? e mail me...
Page 2 of 2 1 2
