crank Offline OP
I noticed that after a week when I spayed the TB as prescribed on the can, I have a CEL Light. I also noticed that the same day I had a CEL light, that the gas cap was off. But I did tigthen the gas cap and disconnnect the battey cables for 5 min and CEL temp diappears. I also check the air filter, never had the wires replaced, but had the plugs replace 25000-30000kms ago. Could it just be the TB cleaner. Did the gas cap off and driving the vehichle cause a problem? Any ideas. Thanks in advance!!!
2001 Cavalier
150-175 more kms
per tank of same size
Pioneer 12 CD Changer
SOLD Green 98 Mystique
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
crank Offline OP
Sorry for double posting, but I also traded that 2001 cav with major dependability problems. I traded for a 2001 Mazda Protege SE. Anybody know of any good protege sites?? Thanks again.
2001 Cavalier
150-175 more kms
GS Sport
Zetec ,ATX
885 Fogs mod.
Hi beam mod.
205 15s
Spraying TB cleaner into the intake will only remove some surface coating and you might have a heavier buildup requiring removal & cleaning of the intake manifolds. (maybe?) Driving without the gas cap wont cause any damage although it may set a CEL which should go away once the cap is replaced. The TB cleaner should not hurt anything and/or cause future CELs. To know if your CEL has anything to do with a dirty intake, you should get the code "scanned" from the PCM computer. Autozone and other part stores will frequently do this for free. Post your codes and let us know what engine, trans, mileage, and mods you have on your car. The codes are also listed here:
http://contour.org/FAQ/FAQ.cgi?s=probs&display=checkengine
Scott
Quote from local Ford Dealer;
"Spraying any cleaner down the TB will do more harm than good! It will cause the linkages to become sticky and may produce CEL. We do not clean them here, we just replace the TB completely!"
This was in response to my question that I asked them about cleaning the TB! After Mr Lube was going to do the "complete" fuel system cleaning and I noticed the warning on the TB warning against spraying cleaner into it!
Stephen
96 Contour, GL, Zetec, ATX.
03/18/1996 Build Date.
Drop in K&N
NGK Laser Platinum Premium Spark plugs
Niehoff Premium Ignition wires
Wheel Well Air Intake Resonator removed.
*Just the beginning*
Originally posted by Stephen:
[b] The TB cleaner should not hurt anything and/or cause future CELs.
Stephen[/b]
You've got to be kidding me. If you're using a cleaner that contains sulfuric acid, I can see their point. Otherwise, Ford needs to sic their attournies on STP, Castrol and everyone else that makes carb/TB cleaner.
Ask the idiot if Ford recommends replacing windshields when they get bug-spattered instead of cleaning them...
TB cleaner shouldn't cause you any problems whatsoever. I've used it on a number of cars ('82 Chevy, '89 SHO, '93 SHO, '99 Contour SVT '00 Vette) with no ill effects at all. Many folks on this Board have cleaned TB's as well as upper and lower intakes and have reported excellent results.
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
Call em' for yourself: 1-780-454-2000 and ask for a mechanic or the service dept!
Why then is there the warning sticker on the TB telling you NOT to spray cleaner down there?
Stephen
P.S. Did all the other TB's that you cleaned also have the protective coating on them?
Drop in K&N
I've seen it on my '99 SVT 'Tour and if I recollect clearly, both my '89 and '93 SHOs had the same stickers on the TB's (anyone that's got a SHO and can check their TB, correct me if I'm wrong).
I've had a very similar discussion before with a mechanic about 8 years ago (i was wary about cleaning them myself, which is why I swear I had those damn stickers on my SHO's). I was told to go ahead and clean the gunk out with a carb/TB cleaner that was safe for FI engines, as my TB's on both the '89 and '93 would get rather nasty.
Now, having said this, don't let the TB SOAK in the cleaner. Spray it and then quickly wipe it off with paper towels or some cotton shop cloths. As you wouldn't take steel wool and gasoline to a teflon pan to clean it, go easy on the inside of the TB.
JaTo
Overland Park, KS
JaTo@kc.rr.com
99 Contour SVT
#143/2760
Modded to Taste
00 Corvette Coupe
Modded to Haste
[QUOTE]Originally posted by JaTo:
[qb]P.S. Did all the other TB's that you cleaned also have the protective coating on them?
Protective coating my @ss. If it were so protective there would be nothing to clean.
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
LOL! eek
Ah, NO! :p
If there wasn't any coating there, there would be more dirt in the TB! wink
Just because there IS a coating in there, doesn't make it impossible to get dirty, only harder to get dirty! wink
Stephen
Drop in K&N
The sticker essentially warns that the teflon (or whatever) coating can be easily scratched off. A soft cloth and TB cleaner won't hurt it anymore than hot exhuast gas from the EGR ports will. As mentioned the coating is not that effective anyway or we wouldn't have the EGR buildup probems many have experienced and cleaned up. I've not seen any faster buildup of gunk or ill effects from gently cleaning the TB and upper intake ports with TB cleaner. (Over 40K miles since initial cleaning...)
Scott
