Ray G Offline OP
Could this be an alternator thing? When I get into higher RPM's near redline the battery light starts flashing and it feels like the car is going to die. Also a whining noise is coming from under the hood. Almost like a water pump noise but I replaced that so it shouldn't be the water pump. Any thoughts? Thanks.
Ray G.
99 SVT
KKM intake
e-ram
B&M short shifter
ASP pulley
SHO shop y-pipe
Borla exhaust
Mintex brake pads
KVR Cross Drilled Rotors
Steel brake line
Koni Adjustable Struts
Eibach Pro Kit Springs
MSDS Headers
High RPMS meaning your flooring it, or your driving around at 6000 rpm? I noticed in my car that when flooring it the batter light would flash at 6,000 rpm. It was my belt slipping no big deal.
thats my case..
Alcohol is my friend
Mongolian BBq S.H.
9
9
Yes it could be an alternator thing. You didn't mention the mileage on your car but as the brushes wear down there is less tension on the springs that hold them on the commutator and at high rpms they start to bounce and lose contact. Hence the warning light. As far as the whine, my car has always had that since I got it last year. It starts at about 3500 rpms.
Karl
*** It's all about consistency! ***
98 SVT Contour
86 Ranger GT
69 Fiat 850 Sport Spider
67 Formula-S Barracuda
Ray G Offline OP
hello,
it mostly happens when I floor it. The car now has 120,000 miles on it. With that many miles and with that whining noise I think it may be the alternator. The noise is there all the time even at idle.
Ray G.
Ray G.
99 SVT
KKM intake
e-ram
B&M short shifter
ASP pulley
SHO shop y-pipe
Borla exhaust
Mintex brake pads
Steel brake line
MSDS Headers
Ray G Offline OP
Anybody else have this problem???
Ray G
Ray G.
99 SVT
KKM intake
e-ram
B&M short shifter
ASP pulley
SHO shop y-pipe
Borla exhaust
Mintex brake pads
Steel brake line
MSDS Headers
Hi Ray,
I had the same problem as you.
I took it into my Ford Dealer and had them replace the Alternator.
Costs me $467 after it all was done.
$202 for the Alternator,
$225 for 3 hours of labor,
and Governor Pataki's 8.25% tax.
Don't try this yourself,
unless you are familiar with pulling your axle.
The RH Axle has to come out, to make room to remove the Alternator.
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
H
H
I am doing my third replacement alternator after autozone has given me two bad ones.
You don't have to remove the axle, just the outer tie rod. Turn wheel all the way to the left. It will wiggle out fine.
98 T-Red Contour LX V6 Mtx 106k miles
9" K&N, Aussie Pipe, Dual Mode Damper, 19lb. injectors, SHM MAFterburner, Ford 9mm Wires, Mystery Mod, ShoShop Off-road Y pipe, Dynomax Resonator and Muffler, 2.5" custom cat-back.
Hey Ray,
I had the same problem with my Cougar. It started with the light flashing at high RPMs, then it started flashing at 4000RPM, then 3000 etc, until eventually the light was on at startup and I had to replace the alternator. It took about 3 to 4 weeks from when the problem first showed up to when the alternator had to be replaced, IIRC.
Bob
Ray G Offline OP
Thanks guys! Very helpful as usual!
Ray G
Ray G.
99 SVT
KKM intake
e-ram
B&M short shifter
ASP pulley
SHO shop y-pipe
Borla exhaust
Mintex brake pads
Steel brake line
MSDS Headers
Hi Ray: Had the same problem last fall. Light would flash at 5500rpm. Did this for a couple of weeks then went constant. Went to a shop right away and they replaced the Alternator. $200+ for the Alternator and $200+ for labor. Visit NE-CEG once in a while!!!
Rick
99 SVT Black/Tan #1090/2760
82K Miles.......B&M Edge Shifter
Mobil1 5-30.....Side Markers
Ford Synth MTX # XT-M5-QS
Locking Lugs....Cup Holders
Black Sail Panels...TH Fix
Aluminum Gas Filler Door
BS Potenza S-03's
KVR Cross Drilled Rotors + Pads
Dual Mode Damper - soon
Clarion head unit
Pioneer 2-ways
