Posts: 13 |
I was trying to find out why my wifes 96 zetec idle would not raise with the ac on. My haynes manual shows a idle increase sol. mounted by the firewall. Is this a v6 only?
Black 96 gl mostly unchanged except for the urge to have it crushed
Posts: 1,040 |
Idle Air Control (IAC) valve, attached to intake manifold on firewall side of I4, is used by PCM to vary idle speed. Does putting a/c on affect rad fan operation? Not sure on this point, but there maybe a difference on idle increase between atx and mtx.
Posts: 13 |
This is not the iac. I have allready replaced that. real pain to get to! Haynes manual calls it a idle increase solenoid.
Posts: 1,040 |
The Haynes manual is unfortunately riddled with European components/systems not on our North American cars. Give me a page/figure reference and I'll have a look. The '97 Ford manual has no such device shown for either engine.
p.s. My fan ? p.p.s. ATX or MTX?
Edit: OK I've found it, seems to be a misnomer for the EGR vacuum regulator solenoid. Follow the vacuum hose from EGR valve and it should go to this device.
Posts: 13 |
Ok. Thanks. I knew I couldn't find it on my car.
Posts: 1,040 |
Just re-read your initial post and realized your initial premise maybe wrong. Why are you thinking idle speed should increase with a/c on?
Posts: 13 |
According to the Mad Mole's page the ac pressure switch is supposed to increase the idle to compensate for the extra load of the commpressor.
Posts: 1,040 |
Read the "Mad Mole" link provided by another member on your other post. Some of the info is wrong IMO. Pressure switch contact activates hi-speed fan operation only, not idle.
PCM continually adjusts engine controls to keep idle within spec., a/c on loads engine, rpm drops PCM compensates (presumably using IAC and injector pulsing) to maintain rpm within I4 idle spec(atx 800+/-50, mtx 880+/-50). If rpm drop by 200 PCM will shut a/c off as it attempts to avoid stalling.
