#763792 10/04/03 05:55 PM
bamf2go Offline OP
Anybody know about the quality of this amp? Compared to the jbl amps? I'm looking at it over the jbl because its 2 channel instead of mono...thd is %0.02, lower than the jbl, anyways what does everybody think? Does soundstream make good amps but this one in particular is a lower end?
P.S. Is the Edge series better, or the Picasso series better?
1998 black Contour SVT E0 -KKM Intake -B&M Short Shifter -SPARCO front strut tower bar -24mm Aussie rear sway bar
#763793 10/04/03 06:47 PM
TGO Offline
Well, while my system isn't complete as of yet I can say that the sound quality is pretty good compared to having my head unit drive all 4 speakers. Also, I only have the front 2 speakers hooked up right now, using the 2 channel amp I plan to use for my sub. Even with only 80W (vs the 110W per channel amp i am waiting for) I can hear stuff I couldn't hear before, and there is no distortion unless you really blast the hell out of it.
As far as how good they are, i've talked to several people about soundstream amps and have heard nothing but good things about them.
And edge vs picasso, I was going to go with a 4 channel picasso which was a good deal more expensive than a 4 channel edge series. dnewma04 recommended goign with the edge series, cause anything more was overkill for my application. All depends on what you're looking for. Hit me up in a week when everything is working nicely and i'm sure i'll have more good to say.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
#763794 10/04/03 06:59 PM
bamf2go Offline OP
My application would be powering a 2ohm dual voice coil Brahma 15 in a 3cuft. box (2ohms: 300watts rms x 2, so 300 watts to each 2 ohm voice coil). That would be 600 watts total, dnew, you seem to know a lot about the Brahma's, would this be an appropriate way to power it or would a class-d amp be better?
Moderated by  dnewma04_dup1
