todras,
I dont need to prove any points. I keep the same screen name and if ya want search around on supraforums and celicasupra.com to see my posts.
I never said they were 4th generation supras. I have 3 MKII's. Two 85's and one 84. I just picked up an 89 turbo so I can pull the 7mgte to put in my 84. It will be pushing 400 HP when I get it installed... without breaking it open...
The 7mgte is a great motor to upgrade and when you drop it in an earlier supra which lowers your weight by 800 or so lbs that makes a VERY large difference in what the motor can do.
They typically run 12's or so when done with a slightly modified turbo and exhaust and stock internals in a MKII supra.
