OK here we go.. 2000 CSVT with 12.2" Wilwood Billet NDL and SS lines all around. Both have been installed for about 9 months.
About 3 months ago my front right brake started to make noise after warming up. (About 8, 25-0 mph stops inside 5 minutes) It sounds like the vibration you would hear from a large truck like duty dump truck. It only makes noise when the brakes are off and then slowly fades over time.
When it originaly started to make noise I pulled the pads and everything looked OK (checked all the bolts were tight ex..). Wheel rotated fine but there is just a touch (very little) pad drag, but not much. So I applied a little "brake quiet" to the back of the pads and for the most part no more noise.
Today I noticed a bit of gouging on the outside the of rotor like a worn out pad would make but it's only 1/16 wide and a bit more than 1/32 deep, located on the rotor about an inch down from the top of the rotor.
Clicky So I pulled the pad and it looks fine, plenty of pad left. I do not have a mircomiter but with a hand rule I checked the pads and they are evenly worn, except for some very, very sligh cupping runnig the lengh of the pad about 1/64 or less at the same location where the gouge is on the rotor.
What I do not understand is how can there be material missing from both the pad and the roter? I could guess that an object was lodged into the brake pad and then scored the roter but then why the odd cupping on the pad.
