The 1995 CD4E ATX was known to blow out the pump seal and cause the 0628 code.
A straight replacement, not a rebuild, is probably the safest way to go.
There are too many new parts to replace, and if not done correctly, can cause too many problems.
For more info go to...
Trans Online ALso, there isn't any drain/fill service on this ATX.
FLUSH is the ONLY service recommended and your FORD DEALER,
has the correct tool to accomplish this with.
