i have a 97 gl but i think it has the sport suspension. my lil bro has a 99 se sport (both v6s) and they have the same size rear sway bar. (i was going to swipe his, he wouldnt notice) i know the pre 98 se is supposed to be stiffer but mine has 100k on it and it is quite soft. i can get the e1 svt susp. w/ 10k on it for around 150 shipped. would i be better off to do this or just get new struts. $$ is an issue. bottom line, if i get the svt suspension will i be dissapointed?
my next point is if i get the svt susp. do the struts need to be replaced if i go to h&r springs later?(when i have $$) i know if you use stock, supossedly, it will cause alot of bounce but are the svt struts good enough?
