Posts: 19 |
Hey All, I have been on and off this board for a while but I need some general info. I replaced my motor in my 95 SE at 76,500 miles due to all the bearings goin out. Well I put a 98 motor in with about 20k on in.....I put about 55000 on it and it went out AGAIN. The bearing for cylinder number 1 went out, lucky nothing else got damaged. So now I am rebuilding this motor. I am putting a new clutch in just because it is all opened up. Is the SVT Clutch any better than the standard SE clutch?? Any other things I should look into when rebuilding my motor?
Eric 99 Maxima SE, MTX, Apexi WS, Clear Corners, Short Ram Intake, Red/Clear Tails
95 Contour SE, MTX, SVT Duals, S&B Intake.....2nd motor...1st Rebuild
Posts: 19 |
BUMP (Or should I say Knock :rolleyes: )
Posts: 803 |
SVT fly wheel would make the biggest difference as it is lighter. However I'm unsure if the OEM clutchs differ.
hunter green 96 mystique mtx, sabb side markers deep tints car bra., K & N filter, hyper white low beams, after market fogs, JVC Kameleon head unit, 600 watt amp with 2 10" kicker subs, soon to come new rims
New adition 01/11/2002 The original 95SE in Midnight Red all the toys including traction control Fog light mod, lightmoonroof switch from a focus, power antena (still wiring it up) post 98 sail panels, new water pump , Bosch quad plaitnum plugs, and a new Cat.
Posts: 19 |
