Posts: 156 |
Well two weeks ago my car was towed to the dealer because the check engine light was flashing and the car was missing and stuff. They told me Monday that there was no compression on cly # 4. They ran some test took the heads off and the piston had a big hole in it....  . So they told me that they had to call Detriot and get a motor build and sent to them so they can install it. I still can't believe that the motor went already.... Has anyone else had have this problem with so few miles on it??
2000 SVT Contour Silver
IN Process "3.0L w/Turbo"
Born In Kansas on 12/16/99 Engine Died on 6/18/2002 18,223 still at Ford as of 7/5/02
#986 of 2150
Posts: 1,664 |
You have a 3L with a turbo, and the dealership looked at it?
Joey 2000 SVT Black #1811 of 2150
Dad always thought laughter was the best medicine, which I guess is why several of us died of tuberculosis.
Posts: 331 |
Originally posted by Joey: You have a 3L with a turbo, and the dealership looked at it? Good Question........
The Stealth Mobile.
Posts: 156 |
Originally posted by Joey: You have a 3L with a turbo, and the dealership looked at it? Sorry, I changed my sig, i meant in process. I have the 3.0L engine and i already have built it up with all new parts. I also have a local turbo shop playing around with a turbo setup. But the car now has the stock engine in it..
#986 of 2150
Posts: 378 |
Are you the only owner?
Get everything and I mean everything fixed/looked at before you get past the three years. That includes taking off your door dings so you do not get stuck with a racing stripe like so many of us.
Posts: 8 |
Hey godzilla, Contours were built at the Claycomo plant in Kansas City, MISSOURI. The only automobile assembly plant in Kansas is the Fairfax General Motors plant. Kansas City spans both the Kansas and Missouri borders, but most of Kansas City is on the MISSOURI side. The little sticker on your window should refer to built in the "show me state" which is Missouri.
-Mark- '99 Mystique LS all options, pure stock 93,000 troublefree miles (knock on wood!)
Posts: 304 |
Yes, are you the original owner? A holed piston is usually caused by detonation (pinging) so I can only surmise that either non-premium fuel has been used or the knock sensor is malfunctioning. I don't know how likely a piston could have been bad from the factory but I suppose anything's possible.
Karl
*** It's all about consistency! ***
98 SVT Contour 86 Ranger GT 69 Fiat 850 Sport Spider 67 Formula-S Barracuda
Posts: 156 |
Originally posted by 98SVT: Yes, are you the original owner? A holed piston is usually caused by detonation (pinging) so I can only surmise that either non-premium fuel has been used or the knock sensor is malfunctioning. I don't know how likely a piston could have been bad from the factory but I suppose anything's possible.
Karl Yes I am the original owner of the car. I always use 93 or 94 octane and i have had the car to the dealer 3 times prior to this for a check engine light that kept coming on, but they didn't get any codes so the cleared the codes and sent me on my way. The car was also hesitating at that time to when you really got on it. I hope I get my car back this week, I miss her
#986 of 2150
