#65243 07/04/02 02:20 PM
markr Offline OP
Has anyone had this problem come up. I deal with a fantastic Ford dealership(they replaced my first engine for me, and have been fantastic ever since), and when the mechanic reads the CEL codes, both banks are coming up lean. He mentioned that it's usually a vacume leak, but there are an awful lot of hoses to be checking for leaks in.
Any ideas?
96 MTX V6, 110K miles
#65244 07/04/02 07:20 PM
I had the same problem. Found a cracked hose at the PCV valve. It's a *&%##** to get at. I busted my cruise control cable trying to change the cracked hose. You should probably change the PCV valve while your in there.
gleschu
