Posts: 383 |
One of my friends told me about this software coming out. http://www.superchipscustom.com/ tweecer is like Dos and this is more like XP check it out. It also will work with 99% of fords EEC's.
98CSVT specII yada yada yada
95 Mustang GT
M&M road&track box
HP stage one
60-mm
Posts: 9,602 |
You mean like this repost... http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=genmods&Number=409668&page=0&view=collapsed&sb=5&o=7&fpart=1Also the price is "suppose" to be around 1 grand.  That's just ridiculous!!! You can almost buy a stand alone fuel management setup when you are talking the 1 grand or better ball park, or 2-3 TwEECers, or ~4 custom chips from SF. Also it has no datalogging ability either. Plus it's looks like it's just a "reflasher" The Tweecer has 4 program positions plus a bypass. (5 total) Reflashed is reflashed! No choices or options to change on the fly. Also you have to be very careful with a reflasher as it is very easy to nuke your PCM. You folks "probably" don't understand how many different programs I've run with my TwEECer or how many it takes for a proper dyno tuning. No way I'd want to reflash the PCM like that!!! Also I expect this to work on just one single application like the Hypertech programmer does. You get one changed program, it saves your base, and that's it. I'll keep my infinite program library, multiple program slots, and datalogging ability.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 383 |
Sorry didn't see that post in the other forum. Also with a tweecer don't risk blowing up your car with incorrect paremeteres? Also wouldn't a tweecer be a calibrator not a true fix since it Doesn't flash the pcm? Why would you need to make on the fly adjustments? Of course there will be difference in air density and such but why would you want to do that when your on a open track event. I can see on the mulitiple postion setting for street driving and such. You mention datalogging wouldn't you want to dyno it to get a true tune anyway so couldn't you have a obd2 prog to monitor the whats going on? With the tweecer does that let the computer alter the tables on the fly? Not being rude just valid questions. I have also been told the tweecer does not switch other calibrations that need to be changed once another adjustment has been made.
95 Mustang GT
M&M road&track box
HP stage one
60-mm
Posts: 14 |
The price has not been set at this time, they have not released a lot of details yet to keep competitors guessing. Once it is released we will have a price, but I don't believe it will be $1000 for the common model.
Don't know yet if there will be a data loging ability with this, but I am doubting it will be included in the handheld version. It may be present in the chip version as it could be done similar to the TwEECer.
There will be two methods, a handheld flasher and a chip version. The chip will be a new Superchips 4 bank chip, this will allow for 4 programs to be stored and the option of turning it off and using the stock EEC as a fallback.
It has been stated on the Modular Depot thread that with the flasher it will currently not be possible to read the data from the stock EEC as a safety feature. When reading from and writing to the EEC the car must be powered on, if power is lost it is possible to be left with a useless EEC. When the flasher writes to the EEC the first thing it writes is the boot portion of the programming so that if power is interupted halfway through you will still be able to start again and recover it. It is recomended that the car be hooked up to a charger when reading or writing to the EEC in order to avoid this happening.
Once used the flasher will be locked to only work with the EEC it was first hooked up to, but will allow you to adjust the programming as many times as you want for that car. There will be a tuner version also which will work with any number of cars but will obviously cost more. With the chip version this limit will not exist since you can only use the chip in one car at a time, but you could use it in any car that has the J3 connector. For example, use it with your truck to get good gas mileage to the track, then move it to your car for racing, and back to your truck for the return trip. This would require a computer and power source, but so does the TwEECer. It may also be possible in the future to buy a license to use the flasher with an extra vehicle, or buy another chip for a second vehicle.
I agree that datalogging can be a great asset to someone who knows what they are looking at. My preference would be to get a standalone package like the autotap tho. This would allow me to use one or the other without having to use both. I could take the autotap and use it on a friend's car without having to dissable my car by moving the chip as well.
Like I said at the begining, the product has yet to be released, once it is, these questions will be answered.
Posts: 1,695 |
From what I've read on the other site there will be different levels of it that will allow different levels of adjustment. Like the first level will have basic stuff and have limits to prevent people from screwing up and then higher up lvls that would allow you to change whatever you want.
Like I've said before.. it will be interesting to see the software and take a look at the product when it is released.
04 Subaru WRX "Eurosport bling bling fast and furious tokyo drift"
"They have diarrhea of the mouth, and constipation of thought"
Posts: 9,602 |
Originally posted by Dustyn: Sorry didn't see that post in the other forum. [sic]
You are way off base about the TwEECer.
The PCM see's the TwEECer as it's actual tables. That should answer every one of your questions right there!
Changing on the fly is as simple as turning the switch to a different slot. As above the PCM see's this now slot's program AS IT'S ACTUAL TABLES.
Everything works as it should.
As for the update on the "flasher" option. 100% pure junk IMO!!! Stay far away from that BS.
If this 4-position chip can accept 100% fully custom programs to by the owner instead of the BS pre-fabbed best guesses then it sounds like it definitely has promise. However you can bet that option is the one in the 1 grand range. OUCH! Then you are right back to the fact a custom dyno tuned chip will garner the exact same results... Unless you plan on changing your setup, programs, etc often it would be an utter waste to drop $1000 for something you can get in the $300 range.
Then there is another fact. Exactly how much of the code for each one of our processor strategies and base code do they have cracked? Remember we are not "Mustang" owners. Each processor and code is different and must be cracked seperately.
Last time Ford chips tried to flash someone's SVT PCM they still couldn't up the rev limiter. Heck a few different people IIRC... Food for thought!!!
2000 SVT #674
Posts: 3,732 |
that looks complicated, and i wouldnt want to risk blowing my engine that i spent alot of money on by doing a bad tune. ill just leave my tuning needs to professionals, streetflight
Russell
Oval Port 3L Nearly Done
Posts: 2,517 |
That's actually what I've been thinking...  Too bad I already bought an Emanage.
Posts: 3,732 |
they are doing my 2 program chip, and ill fine-tune it with my s-afc II on a dyno
Russell
Posts: 5,810 |
Why?
I use the chip and the emanage! They work great together.
Tom
See My Mods
