Posts: 7 |
i just bought some denso iridiums from anoter CEGer. his brother got them off ebay. the add said they are for a contour svt. he didnt want to bother with them. i was wondering the results some of you guys have had and if you have the product # so i can make sure mine are ok to put in my car. there are 2 #s IT16 and 5325. some one please let me know something soon! thanks, jared
Posts: 7 |
i read some of the comments about the plugs and i wanted to make it clear that im not expecting a huge hp boost. i heard they were good plugs from a buddy of mine who is into imports and has a FAST modded prelude. i figured at $40 if they only last 60k and dont even give additional power then they were worth the money. but i dont want to put anything in my engine that will screw it up either. id rather cut my losses now.
Posts: 1,017 |
why bother when you can get autolite double plats for like $6 each? spark plugs aren't going to give you an HP boost, and only a minor increase in your gas mileage (unless your current plugs are in really bad shape).
1995 SE
2.5L V6/MTX
187k
Posts: 9,602 |
You only want to install double platinum plugs. (use search - ad nasuem - sheesh)
Put the Iridiums back on Ebay. They will do you much better there than in your engine and that's for certain!
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,859 |
IT16 are the right plug. Try them out and let us know
'99 Silver svt
For sale
19" Axis Neo wheels
3.0 parts, pre-98 trunk,
Check classifieds
bp.powell@comcast.net
Posts: 266 |
Here is a diagram of the D.I.S. that is used in the DuraTec ignition system. Note that one side actually must fire in the reverse direction. That is why the unusual requirement of two platinum firing tips.. one on the center electroid and one on the outer electroid. I have only found the two companies, Autolite and Motorcraft that have this option. DIS Coil Secondary Winding
Posts: 1,228 |
Originally posted by mr_froge: Here is a diagram of the D.I.S. that is used in the DuraTec ignition system. Note that one side actually must fire in the reverse direction. That is why the unusual requirement of two platinum firing tips.. one on the center electroid and one on the outer electroid. I have only found the two companies, Autolite and Motorcraft that have this option. DIS Coil Secondary Winding
Linky no worky
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
