#65201 07/04/02 12:05 AM
Aroneng Offline OP
Engine running too lean code:
Update so far, I have changed the fuel filter, sparkplugs, pulled the injectors, cleaned the air flow sensor, and checked for vacuum leaks.
My next item is to change the PCV valve (what an awful location) and check for vacuum leaks with that line.
Any other recommendations if this fails?
Thanks
#65202 07/04/02 12:24 AM
O2 sensor?
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
