#65183 07/03/02 08:20 PM
Y
Y
My fog light burnt out...what all is involed in changing it? Thanks...also...is there a cheaper route than gettin the bulb from Ford??? Like Pep Boys or something? Thanks
1999 Silver Frost SVT
completely stock under the hood
Focus SVT door sills, Fog light mod, Sony X-plod CDX-M750 head unit
#65184 07/03/02 08:32 PM
I believe it's bulb #893 and you should be able to pick it up at AutoZone or Pepboys.
#65185 07/03/02 08:33 PM
pep boys has the fog light you need.Just reach up behind the fog light and twist it out.Bulb #893
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
#65186 07/03/02 10:07 PM
Weird but I ust changed mine. On my SVT I found that turning the wheel in helps to get at so you not squeezing you arm in there. You have to unscrew a couple bolts and reach in and like what was mentioned, just turn and in should pop out. Then just hit the release button and in should detatch from the wire harness. Easy enough.
Brian
2000 Silver Frost SVT
Build # 1724 of 2150
Gun Metal Motegei 17in. rims
KKM Induction
Kenwood KMD-X92 Excelon Mini Disk Player
Pioneer Horn Speakers front & back
MOMO F-16 Carbon Shift Knob & MOMO Carbon Door Kick Plates
-Door Ding Gaurds
Melting tire rubber is a sign of a fast car!
