Ok here is my problem. While I am driving my transmission disengages from the engine and if I press the gas, my rpms fly to 6000. About 2 seconds after the transmission disengages, it reengages and I go on like normal. Now this happens randomly and i can go 5 mins without a problem, or it will happen more than once in a minute. It seems to be getting worse. I am guessing I am losing power to the car because sometimes when the transmission disengages, the stereo also turns off. Then it restarts.
Ok my second problem, My power steering is leaking at the pump side. The pump is located directly above the alternator. It has leaked fluid all over the alternator. I am guessing that the alternator may be shorting out while I am driving. I dont know if that is the problem or not. I have not fixed the leaking yet but when I do I will try to clean out the alternator to see if that was the problem. Just trying to see if anyone has had this problem. I really need help I cant really use the car. Thnx everyone.
