About a day ago I changed my dpfe, maf, iac sensors. So I went out to drive around to see if it helped my hesitation problem. Anyways as I was driving around my cel came on so I decided to drive to autozone to get them pulled. Anyways after about 10-15 minutes of driving, when I would step on the gas the car would rev to about 3500 and I could only go about 30, almost like the car didnt want to shift into second gear. I pulled into autozone whom was closed, poped the hood and the engine seemed to be moving around more then usual, and the car was chuging and trying to die. So I went back home and on the way I could only get the car up to about 40, and then after pumping the gas, I heard a snap and then the car would take off, then the same thing would happen when I got to a stop light, 30 mph and then it would kick in and go with a snap sound. I can drive it for about 10-15 minutes before the problem occurs. Does this mean my tranny is going? Today the problem started to occur and when I let off the gas the car died, but restarted right away. Fluid doesnt smell burnt, but im not sure when it was last changed. I was told it could possibly be my fuel pump, but then again that was a guess. 95 zetec 4.0cl 100,000 miles I could really use some advise!!!
Thanks
