kcobra Offline OP
i have been having trouble codes o172,0175 for a few days now and i deas on what might be causing them
98 se mtx
k&n air filter custom short shifter
intake res removed
SVT Exhaust shoshop off road ypipe
svt clutch pres. plate ,flywheel, and trans
SVT gauges
SVT front bumper
SVT wheels
fogs /parking
airbox baffles removed
P0172=System Too Rich - Bank No. 1.
P0175=System Too Rich - Bank No. 2.
1996 Contour SE Sedan 4D (Royal Blue)
Duratec V6 2.5L 24-valve DOHC
Automatic
75,000 miles
No Mods (unless you call the DMD a mod)
Replaced EGR valve (gunked up), EVR (EGR VR), PCV valve, and evaporative emissions hose (cracked).
kcobra Offline OP
i know what they mean i am trying to figure out what is causing them
98 se mtx
intake res removed
SVT gauges
SVT front bumper
SVT wheels
fogs /parking
Possibly some obstruction of the intake air flow. Is your IMRC opening the secondaries OK? Do you have plugs not firing/missing?
Scott
kcobra Offline OP
yeah my 2ndaries are opening ok dont think i have anything plugs missing but if i did how could i tell if the were missing it sure does not feel like they are
98 se mtx
intake res removed
SVT gauges
SVT front bumper
SVT wheels
fogs /parking
The following is from the Ford TSP:
Diagnostic Trouble Codes (DTCs) P0171 bank (1) (cylinder #1) and DTC P0174 bank (2) indicate the fuel/air ratio is too lean. The fuel adaptive system is at the rich correction limit.
DTC P0172 bank (1) and DTC P0175 bank (2) indicate the fuel/air ratio is too rich. The fuel adaptive syste is at the lean correction limit.
DTCs HO2S Reference list:
-- HO2S-11 = DTCs P0171 and P0172
-- HO2S-21 = DTCs P0174 and P0175
Possible causes:
Fuel system
-- Excessive fuel pressure.
-- Leaking fuel injector(s).
-- Leaking fuel pressure regulator.
-- Low fuel pressure.
-- Contaminated injector(s)
Induction system
-- Air leaks after the MAF.
-- Vacuum leaks.
-- Restricted air inlet.
-- PCV system.
-- Fuel purge system.
-- Improperly seated dip stick.
EGR
-- leaking gasket.
-- Stuck open EGR valve.
-- Leaking diaphragm.
Base engine
-- Oil overfill.
-- Cam timing.
-- Cylinder compression.
-- Exhaust leaks before or near the HO2S's.
Automatic
75,000 miles
