Posts: 20 |
I'm planning to change the MTX oil,shifting is ok,what oil I can use,10w30?
Posts: 1,459 |
No, not 10w30. The mtx uses ATF fluid. There have been a lot of discussions in the past concerning the best. A lot of people will add a friction modifier to the ATF fluid. Personally, I use ATF-III.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 1,085 |
Originally posted by bentleywarren: No, not 10w30. The mtx uses ATF fluid. There have been a lot of discussions in the past concerning the best. A lot of people will add a friction modifier to the ATF fluid. Personally, I use ATF-III.
Yup
2012 Lotus Evora
95 Mystique MTX - GONE 395,000 Kms
--------- Both Zetecs
'97 Contour Mtx - stock - GONE
Posts: 1,746 |
Some people use ATF fluid, some people use manual transmission fluid. As stated, this has been covered many, many times.
Posts: 3,867 |
Search the transaxle forum for "Redline MTL" and "Ford Synthetic"
That should give you the info you crave (and then some.)
Function before fashion.
'96 Contour SE
Posts: 1,834 |
Also search for tranny cocktail, might have to go to the archives for that. Use ATF though, I was told by Terry H. that MTX fluid (gear lube) is simply too thick for our trans, which was designed to use ATF.
Shawn Clone
Jezabel- 1999 SE Sport V6 MTX- Severly wounded, comatose
Silver frost/Black Exterior-Midnight Blue Interior
The Firecracker- 1995 Mystique LS V6 MTX stock and backfiring like a rifle shot
I have 3 loves, my God, Brittany, and my Car.
Posts: 3,867 |
Originally posted by NorMich99SE: Also search for tranny cocktail, might have to go to the archives for that. Use ATF though, I was told by Terry H. that MTX fluid (gear lube) is simply too thick for our trans, which was designed to use ATF.
He also likes the Ford "honey," which, IIUC, is Ford's newer synthetic. Apparently the original fluid has a habit of gunking up? Definitely not my area.
'96 Contour SE
Posts: 3,506 |
I reconmend using Redline MTL Fluid...I find it better then the ford honey or the Tranny Cocktail. But again, i have Terry Haines Bulldog tranny with the upgraded flow chanels. But form what i researched , with a stock MTX, the Redline MTL would provide more than enough protection for your trans.
Givin its 12 dollars a quart in my area, but it is well worth it...that may be some thing to look into before you decided to chose a your fluid.
Roz
Posts: 4,714 |
Originally posted by Roz 1999 SVT-C: Givin its 12 dollars a quart in my area
Summit Racing has it for $8/quart. I have three sitting in my garage waiting for the opportunity to go in
Linky
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 3,506 |
Originally posted by hetfield: Originally posted by Roz 1999 SVT-C: Givin its 12 dollars a quart in my area
Linky
Thanks for the link...i will remember that for the next time...the info is appreciated!
Roz
