Posts: 1,145 |
98.5 Black SE ATX
Posts: 20 |
Posts: 1,145 |
98.5 Black SE ATX
Posts: 103 |
that sounds about right... 200miles w/ a qtr tank left. thats what i get. Our tanks are if i'm not mistaken 14 gallons, when you fill up (i fill up at around 240 miles) thats just flirting with the gas light coming on, i usually have 2 gallons STILL in the car because i usually end up paying for 12 gallons. so instead of dividing your total mileage by 14 (the size of our tanks), divide by 12 and that should give your a smoother, not so rough estimate.
Jeff Silva
E0 Contour SVT Silver
-STEEDA PEDALS
-K&N Drop In
-Ford Racing Wires (w/Bosch +2's)
-Cleared Headlights
-Yokohama AVS ES100's
-Alpine CDA7893 w/MBQuartz
-EUROLITE 9006/893
Posts: 1,228 |
I get 25MPG Avg (over 35K miles). Lows are 19-20 (winter, highest is 34 MPG on 400+ mile trips. I track all my costs as I use the car for work. Interestingly, the 34 MPG was on trips to Pittsburgh and Charleston, WV. and I was traveling in the 80 MPH range most of the trips (just keeping up with the tractor trailors). The car does like high speeds.  The only performance mod is a drop-in K&N Filter. I keep the tires (Falken Z-502 205-60 HR15) at the sidewall max pressure of 44PSI. Rides a little hard, but handles well and doesn't mind rain.
BEFORE: '99 Contour SE Sport
Duratec ATX Spruce Green
Posts: 405 |
i usually get 240-280 miles out of a tank of gas. And that's with the air running non stop in the summer.
Tony Datsenko
Posts: 1,228 |
Originally posted by Dark Sport: i usually get 240-280 miles out of a tank of gas. And that's with the air running non stop in the summer.
With a 14.6 gallon tank, that's only 17-20 MPG if you ran to empty. An MTX should do better than an ATX (or not).
How much gas does a "Tank" mean? 10 gal= 24-28 MPG, 12gal means 20 to 23 MPG.
Posts: 2 |
I once got 46 mpg coming back from Vegas at 65 mph but I usually get 40-43 on the same route.This is with a 4 cylinder engine and standard transmission using premium fuel.I also use Mobil-1 oil which reduces friction.The worst I got was 39 mpg at 70-75 mph and a headwind.
Posts: 405 |
um, i ussually get 10-12 gallons when i fill up.
Tony Datsenko
Posts: 101 |
Best ever was this summer after doing the y-pipe mod and K/N filter in the airbox, 41 mpg. The y-pipe mod
is worth every cent it cost to do it !!!!
Edit: Equivalent to 34 miles/US gal. Presumably hwy considering location
96 contour SE,E1 rims w 205/60/15 Comp TA's VR4's,optimized y-pipe,SVT doorsills,KKM intake,BULLIT MUSTANG fuel door,painted grill,every available option w/leather !
95 mystique LS,every option minus leather,optimized y-pipe+exhaust
