#65050 07/02/02 12:12 PM
My SVT has 54,6xx miles, and I'm running BFGoodrich T/A KDW's, which have a reputation for creating a lot of road noise - the tires are probably not quite halfway through their tread life.
Anyway, driving the car has become almost unbearably loud, especially between 60 and 65 mph - loud enough that it's difficult to have a conversation in the cabin. The noise drops off fairly substantially once you get above about 68 mph or so, but is still quite noticeable.
What makes me think that it's a wheel bearing is that the noise is most pronounced when I either have the steering wheel perfectly straight, or when I am going around a sweeping left-hand curve. When I go around a sweeping right-hand curve, the noise virtually disappears.
The easiest thing, I suppose, would be to swap the KDW's off for my snow tires (BFGoodrich Winter Slaloms) and see if the noise goes away. Before I do that, however, is there any way to diagnose a wheel bearing problem before I take it back to the dealer?
I bought an extended warranty out to 75,000 miles, and I am pretty confident that a wheel bearing replacement would be covered. I just want to know if there is any way for me to confirm it for myself before I get the dealer involved.
Many thanks in advance.
1998 E1 SVT - Toreador Red
Production #4794 of 6535
Build date: 2/25/1998
Mods completed:
- Pre '97 sail panels
Mods planned:
- K & N Air Filter
- Side marker lights
H
H
Seems to me like you've done the usual diagnosis which identifies problem with front right wheel bearing; I replaced my 97's at 60,000 miles due to noise.
Lower speeds until replacement might be good for your health.
stock CD on LS, cass on LX
4 wheel discs on LX only
N
N
mine is loud too, but seems to come from the rear wheels. How much are bearings all around?
Front?
Rear?
My rear end had a lot of road noise too, and I was CONVINCED it was bad wheel bearings (at 50,000mi). And I'm even a mechanic! But I just milked it for a long time, waiting to see if they would get worse. I mean, it was LOUD! Just like bearings. Then later on, when my tires got old and weren't really legal (at maybe 65,000), I put new tires on. And guess what? Quiet as snowfall on a cool winter's day! And now I have 105k miles and still quiet as can be. I would try tires first smile
'95 CONTOUR SE
-Enkei 16s
-Porsche944 Exhaust tip
- Audi xenon projector headlights
-Peterbilt 30" air horns
-mp3 Aiwa headunit (150 songs on one disc)
-dual 10s
-soon to have LED tailights (real kind, not just gay bulbs)
-That's it for now
My tour has the same symptoms and get's quiet when sweeping to the right. I've jacked the car up and the right front wheel has quite a bit more play than the left. The bearing is about $45, but you need a press (machine shop style) to get it out/back-in the steering knuckle.
Scott
Jack the wheels up and give each some firm shakes. If it moves on the horizontal axis, it's a wheel bearing. If on the vertical, it's probably outer tie-rod ends.
H
H
Your ear is best diagnostic tool for early faulty wheel bearing detection. Play in jacked up wheel more likely ball joint (vertical) or tie rod (horizontal).
****e, you are very correct. My left wheel bearing was cooked enough last year that the wheel had some slight longitudal play. (VERY bad)
That's what I used to think.
'95 CONTOUR SE
-Enkei 16s
-dual 10s
-That's it for now
E
E
My tires are so loud, I didn't notice the sound until someone pointed it out. (Left front, 80k miles)
I guess I should get my tires replaced before I can't hear anything failing. Then again, maybe we should be shooting for louder tires!
laugh
