Posts: 20 |
The clock will not light up ,Is there a bulb I can replace?
Posts: 800 |
Originally posted by zzzqqq: The clock will not light up ,Is there a bulb I can replace?
yes. take the black piece of the dash out, should be about six screws.
Posts: 4,693 |
If you have a Contour the clock can be pulled out without taking the dash bezel off. You can gently pry it out with a pocket screwdriver. If you have a Mystique, you will need to remove the dash bezel to get to the clock. Once you have the clock in your hand, you can find the bulb on the backside. The bulb comes out with it's base/holder. You should be able to get a new bulb from the dealer for less than $5.00. I don't know of another source for the bulb. If you do a search you can find more detailed instructions along with the part number. Make sure to transfer over the green plastic sleeve from the old bulb. Ford does not sell the colored sleeve by itself although you can find one at www.partsexpress.com part number 070-082 (I think). About $2.00 for a package of 10.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 4,714 |
Originally posted by Big Jim: Ford does not sell the colored sleeve by itself although you can find one at www.partsexpress.com part number 070-082 (I think). About $2.00 for a package of 10.
Correct, the price is $1.70. And Jim this info couldn't have come at a better time since I will be ordering the blue sleeve (part 070-086) for when I install blue LEDs in my car. Thanks!
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 888 |
another source for the bulb on our 96 contour was that i took the old bulb out and went to Auto zone and found two bulbs in a pack for about $1.98 and i took the two wires that were in the back of the bulb and bendt them over and then put them into the metal clip that is on the original bulb that holds it in place and used it to keep the new bulb in place... i dont want to pay any $5.00 for a bulb at the dealer like the one to illuminate the inside door locks... you can improvise if you look around......
Posts: 20 |
Thank for all the reponses,it was my lucky day,the buld came back to life when I prying the cover out!
Posts: 429 |
Mine just went out. The clock pops out easily with just a screwdriver. The bulb is behind the removable white plastic piece on the back of the clock. However the bulb fits inside a black plastic holder (1.2 W, 12V) and cannot be removed from it. I tried Autozone today and they didn't have anything close to it. I guess its a stealer, er, dealer item!
Dan B.
96 SE 2.5 auto
Posts: 429 |
Just bought a replacement bulb from my local Ford dealer for $4.62, including tax. Not real bad, but not cheap either!
Dan B.
96 SE 2.5 auto
Posts: 2,319 |
Originally posted by dbird: ... you can improvise if you look around......
... or alternately read the FAQ section clock light
Posts: 118 |
Hey my clock went out and I added a blue LED. Now all the digits are bright blue. Everyone loves is. I will get pictures up tomorrow. I am repairing the leaking power steering right now.
1995 Contour LX (ATX)
KKM True Rev Sport Induction ( Video )
Alpine CDA-7894 / JBL 1200W AMP
12" MTX Subs 5x7 Alpine Mids
Brullen mandrel bent quasi-dual exaust
