Sometimes when i start my car (95 stique gs 4 cyl) it hesitates to start and i have to give it some gas (not a lot just a little). Then while driving the check engine light came on for a few seconds.
Since i am a new-b at car problems i thought either a battery or alternartor or is it something else
95 'stique gs 5-speed - Matty #10
H
H
Get that code pulled and post it here. It may point to the problem.
I agree, have your codes pulled. Call around, some of the parts chains will pull codes for free, and they may also be able to test your Bat. and/or Alt.
If the engine is turning over (cranking) then the battery is probably OK. The alternator charges the battery and provides the entire system with power when the engine is running, so it is probably OK too.
Sounds like you have either an ignition or fuel problem.
Check engine light is usually for emissions related faults. If you have a battery or alternator problem you get the generator light. (Can't remember what it looks like???)
I would say get the codes read and then go from there, but how old are your plugs and wires? It might be time to change them out.
Traded in - 2000 SVT Black tan leather DMD, Pro-Flow 75mm MAF, SHO Shop Intake Mystery mod(awaiting installation) Now 2004 Acura RSX Type S 2003 Honda Civic Hybrid
i just had the same problem, if that light came on, it was probably from hitting the gas while starting, cause a bad mix during the start up probably O2 sensor.(thats what my code was) mine also was have trouble starting, it would turn over, but not like usual,kind of slow at it. i took the battery in and had it checked, it was the problem. i put the new one in and it kicked right over.
