Posts: 233 |
Do the mazda 626's use duratek's ?
98 csvt, no res, bm shifter, sho-shop intake. "wherever you go there you are"
Posts: 3,223 |
Posts: 233 |
I had a 82 mazda b2000 and it was the exact same thing as a ford curior. It makes sense wouldnt it, ford could have saved alot of money. look at the probe and mx6.even the rangers share the same platform explorers too.
Posts: 515 |
FWIW, the Ford Courier was a Mazda rebadged.
Around that time, Chevy had the little pickup "LUV" Was an Isuzu.
Chrysler had the Mitsu's ie: Ram50
The big three all had Japanese PU's then so as to get into the market quickly. Ironically, the Japanese are using the american iron quite a bit for there stuff now, IE Mazda B series is a ranger, Isuzu uses S-10.
"My Name is Richard. I am a Contouraholic." 1999 SE Sport Duratec ATX Spruce Green; Drop--In K&N Filter; VentShades; Fog Lamp Fix Mod & PIAA510s with Bumper Braces & Stock Type aiming screw mod; PIAA 9006 Super White Headlamps AIWA CDC-MP3 HU; WeatherTech Mats Viper 600ESP w/Remote entry
Posts: 1,795 |
that 2.5 (626) was also used in the probe gt and mx-6, I bet it's days are numbered
-Pete
Every time I come online I wonder if the forums will be up
Posts: 7,329 |
Originally posted by dubkatz: Do the mazda 626's use duratek's ? They never used the Duratec either... :p
Posts: 1,493 |
The 2003 Mazda 6 will use a new vsersion of the Ford Duratech!
2000 SE fleet, V6, ATX, ABS, no spoiler, T-Green/tan. Built 01/2000 in MO. Added 12 spoke factory SE rims, K&N. Biggest mod: ESP Plan!
Posts: 2,961 |
Originally posted by Contouraholic:
Ironically, the Japanese are using the american iron quite a bit for there stuff now, IE Mazda B series is a ranger, Isuzu uses S-10. Don't get me started on how Ford's ridiculous parsimony wrecked the B-series by putting it on the Ranger platform and alienating the Mazda truck's customer base. Now they want to ruin the Protege the same way by sharing a platform fith the Focus. Keep them separate Ford, and enjoy owning more breadth of the small car market.
You can pillage an enemy once, but a customer is an endless resource.
James Oerichbauer - PFPC Global Fund Services
Ross: 1998 E0 SVT Contour, Toreador Red, Konis, Superchip, KKM w/heat shield, SHO-shop y-pipe and rear strut brace, no res, ScotchCal, Moda Sport 16x7.5 wheels with 205/55ZR16 Dayton Dayton tires... more
Posts: 583 |
Originally posted by dubkatz: Do the mazda 626's use duratek's ? Go to Corksport.com if you have the 626,MX-6/3 or PGT and get the 2.5 Jspec engine and computer and do that swap.. 200hp and will eat up a NA stock svt, I know a guy with a 2.5 Jspec engine in his MX-3 and kills me buy 3 car lenghts. I believe he told me he was running high 13's and the way he stomped me I believe him. Eric
First I would like to congratulate my 2002 "The Perfect Storm" undefeated National Champions MIAMI HURRICANES*1999 Ford Contour SVT #206 00 SVT motor with Return fuel*Black-Tan*Cold Air Intake with 6" S&B Funnel Ram*Sho-shop off road y*Brullen Cat-Back 3.5" slant tips no res*Unorthodox racing crank pulley*Lotec Guage pod with Air/Fuel, Oil Pressure and Voltage*17" Image Tuners*215/40 Falken Ziex's* B/M Short Shifter*Nokya 9006/9005 80w/100w Xenon's*JSP wing*BNM White Faced HVAC*Custom svt emblemed rear*Bosch +4's*H/R springs*Euro Sidemarkers. Eric@ritterpenusa.com Centerforce Dual Friction Clutch and Fidanza Flywheel.
Posts: 515 |
Originally posted by svtcarboy: Originally posted by Contouraholic: [b] Ironically, the Japanese are using the american iron quite a bit for there stuff now, IE Mazda B series is a ranger, Isuzu uses S-10. Don't get me started on how Ford's ridiculous parsimony wrecked the B-series by putting it on the Ranger platform and alienating the Mazda truck's customer base. Now they want to ruin the Protege the same way by sharing a platform fith the Focus. Keep them separate Ford, and enjoy owning more breadth of the small car market.[/b]The Escort is/was on the Protege PLatform (which improved the product, Escorts had a high reliability rating). I bet the Protege will be degraded if it goes to the Focus platform. It's getting harder to buy a "genuine" Japanese car.
