Originally posted by WilliamMHolla:
...... When you do this a funny burning rubbery smell comes though the vents when A/C or fan is on.....
This symptom, by itself, might indicate a problem with the fan (blower) dropping resistors which is an item covered by a "recall" - Ford fixes only if there is a problem.
I think you probably mean the DPFE (Differential Pressure Feedback EGR) sensor, which has 2 hoses attached to it. BTW these hoses are special (high temperature) and presumably you re-used the originals and did not substitute another type.
