#750236 09/18/03 03:33 AM
9
9
I have a few problems with my power windows, first of all my back right window will not role down 1/2 the time and if it does it's because I hit the switch like 10 times in a row. Plus the passenger side window has the same problem but not as drastic, has anyone had this problem or am I the only lucky one???
#750237 09/18/03 07:44 PM
Need new switches more than likely, had the problem where some would work some wouldn't, I replaced all 4 switches, everything worked fine, after 120$ in parts. what you will want to do is remove the switch on the problem window and see if you are getting voltage there, i still got voltage at all parts, but it was the switches, and its prolly the master switch only. do some electrical diagnosis like that and if it still does the same thing try a new switch, or one from a Junk yard if you can find one.
Alan 93 Acura Integra LS 5spd Horizon Gray Metallic ------------------------- -96 Gl Zetec ATX- Totaled as of 11/29/03 at 4pm Champagne Metallic CC Pics
