Posts: 149 |
Has anyone installed either a quaife or torsen by themselves? If so, how much time did it take you? Any special tools? Mechanical skill level required to do it?
JayBo
"I'm not above the law, I'm beyond the law"
1999 CSVT Toreador Red
Magnaflow Resonator and large K&N
Posts: 21,197 |
No. We source it to a professional due to the pressed bearings.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,713 |
One could just have the bearings pressed by a mechanic and do the rest his/herself, no?
Derek
Scion xB 5-spd
Previous: 2000 Silver Frost SVT
Please share the road with cyclists.
Posts: 2,728 |
You watch your mouth. That tone won't be tolerated in this forum.
'03 SRT-4
50 trim turbo + support
Posts: 4,713 |
Originally posted by RyeLou: You watch your mouth. That tone won't be tolerated in this forum.
Me? What'd I do? What ever it is, don't tell my parents, ok?
Derek
Scion xB 5-spd
Posts: 2,728 |
hahah I need
'03 SRT-4
Posts: 106 |
It wouldn't be that hard to do, I don't think. But probably would require some experience in making sure the shimming was correct. To be fair, I've not put one in the MTX75 myself, so I'm not 100% sure. But with other Ford transaxles I've had apart that were of that basic configuration, it was simply a matter of removing the bellhousing half of the transaxle case and then lifting the diff out. No further disassembly was required. IIRC, from what I understand, the MTX-75 shouldn't be much different. Can anyone varify that?
Rick Barnes
'66 Ford Ranchero
'84 Ford EXP Turbo Coupe
'88 Mazda 323 GTX
'88 Mazda 323 SE/GT hybrid
'93 Ford Aerostar XLT AWD
'99 Ford Contour SVT
Posts: 1,860 |
I assisted in the process but can't claim credit. The torsen just dropped right in. I didn't need any shims. I also kept my stock speedo gear. The hard part was getting all the other stuff back in and closing the case. I remember he had an especially hard time with reverse.
2001 Lincoln LS8
1994 Lexus GS300
Posts: 270 |
How many hours labor for a decent transmission mechanic if the trans has already been dropped?
99 E1 SVT
Black/Tan, MSDS Headers, SHO-Shop Y, BAT Intake, Opt. TB, UR Clutch/Flywheel, Quaife, B&M, Konis, GC Coilovers, Pulley, Mintex Pads, 17" MAS Italy Rogers, Nitto 215/45/17, Portmatch, 138K
Posts: 64 |
From a local trans shop, I was quotes 1.5-3 hrs for a quaife. He said it shouldn't be more than 2, but he has to over quote me.
I decided to get it done by someone else in the end anyway.
99 Cougar V6 MTX...Plenty of mods
My best mod thus far:
Trans: Brand New MTX-75 with B1 gear set, Quaife LSD, 4.5 Final Drive, Spec Stage 1 Clutch, Spec Aluminum Flywheel...
