Whenever you replace the H2O pump you should ALWAYS replace the tensioner. I was a bit surprised when a Ford mechanic told me this but when I went to do the install of my new Federal Mogul PLASTIC impeller H2O pump I found the tensioner was seized. Do yourself a favour and replace it now to confirm the tensioner is not the cause of your problem.
2 years + and NO problems with my pump, even if it has a plastic impeller. The quality of name brand products speaks for themselves. I do know of others who installed metal impeller pumps and had troubles later....
Redcoat Raceworks. Performance parts and custom fabricating for Contours, Mystiques and Cougars. Specializing in chassis and suspension parts. Custom end links, control arms, strut tower bars, engine torque braces, etc.
