#64880 06/30/02 08:43 PM
i'm having a promblem with the overdrive a knocking and slaming of the tranny ??? someone told me its the overdrive swith ???? is this the inhibtor swith on the tranny??? or what is it ????
robert atkinson
#64881 07/01/02 01:55 AM
The Overdrive switch is on the gear shifter, green button where your thumb would rest when holding the shifter. This switch is used to disable 4th (overdrive) gear. Check your tranny fluid level and condition. It should not be dark brown/black or smell burnt.
99 CSVT Green/Tan 13,700Km
# 84 of 2760
For Sale
96 Contour GL 2.5 ATX 120,000Km
K&N Air Filter
Mobile 1
E1 SVT Wheels & BFG G-Force Rubber
Aluminum Painted Front Grill
#64882 07/01/02 07:06 AM
The button on the shifter is used to diable the Torque Converter Clutch, NOT 4th gear.
You will still get three upshifts, even with the Torque Converter Clutch disabled.
Rob, what year is your GL, is it a Zetec or a Duratec, and how many miles do you have ?
When was the last time the transaxle was serviced ?
Pete...
98.5 SE Sport Duratec ATX (P66L)
Black Clearcoat on Greystone
DOB 11/21/1997
DOP 12/25/1997
PIAA 510 Super White Driving Lights
SVT CAT-BACK EXHAUST (No Resonator)
DiabloSport Chip (LPQ4) - Engineered To Raise Hell
Too many other mods to list...
Sounds sweet, runs quick...
Crazy Horse Dyno @ 121.4 WHP/129.6 TQ
#64883 07/01/02 12:24 PM
H
H
Originally posted by RoadRunner:
The button on the shifter is used to diable the Torque Converter Clutch, NOT 4th gear....
From the '97 Ford service manual:
"Drive is the normal selector lever position for most forward driving conditions. This position provides all automatic shifts (first through fourth), apply and release of the torque converterter clutch, and maximum fuel economy during normal operation. Fourth gear (overdrive) may be cancelled by pressing the Transmission Control Switch (TCS) that is located in the shift knob."
stock CD on LS, cass on LX
4 wheel discs on LX only
#64884 07/01/02 01:48 PM
my mechanic change the fluid and it still was jumping he sas its the overdrive switch because when it happens after driving and starting back up when i press exceleratorthe car jjumps into gear and sometimes the overdrive lite in the counsel blinks on/off but ater i drive for a while its fine like nothing wrong i'm at wits end its a painin the butt. i 'm open to any suggetions its a 97 duretec 2.5 only have 51,000 on the car
robert atkinson
