Posts: 284 |
Here are the problems... I know my CAT needs to be replaced (car has just under 63K miles) My cars idle jumps when I come to a stop, from about 600 to 1100 RPMs... I have poor gas mileage...And the car seems to have lost about 10-20HP... I took the car to a local Ford dealer and them run a dia. test for me... The guy told me that the O2 sensor was sticking (they don't stick, they either work or they don't) I asked him which sensor it was, he replied my car only has 1 O2 Sensor, so I bought a Bosch O2 Sensor and replaced the one at the front of the engine (right by the access panel to the fogs) and reset the computer and went to work... On my way home that night the CEL came back on and it started acting up again... What else could be bad? I'm thinking it's the EGR valve and I may need to clean my TB...The car is a 1997 GL Sport, Zetec, MTX... Thanks in advance...
~*TJ*~ 97 GL Sport Zetec ~*RIP*~Connie~*1/21/02*
~*Mods*~ E0 SVT Rims~205/55R16 Goodyear American Eagles~
~*Mods to come*~ H&R springs~Konis~Coilovers~17x7 Millie Miglia Avia~215/45R17 S-03's~SVT body kit~98+ OE Spoiler~CAI~Brullen Cat-Back~Turbo (or 2):)~
More to come
Posts: 724 |
Lovely Winchester Ford. Sounds about right with the EGR, cleaning the TB couldn't hurt either. Try it and see what happens. BTW a fried cat will make you lose 10 hp, trust me I know first hand.
Ryan
98 V6 Lots-o-mods SOLD 88 Daytona Shelby Z TII (The beast) 87 Daytona Shelby Z TII (Holy 20 psi of boost batman!) Mods- 3" Downpipe, Hi-Flow cat, 3" mandrel bent exhaust with Dynomax Ultra flow. Manual boost controller, TurboXS blowoff, 5th injector, large canister wastegate, Nitrous Express go-fast-be-happy kit, ported exhaust manifold, ported intake manifold, upgraded motormounts, eibach springs, strut tower brace. Oh and 20 PSI to boot.. my oh my...
Posts: 284 |
Hey Ryan, do you know any good shops around here that could replace my CAT? For a decent price? Thanks, TJ
More to come
Posts: 229 |
It could be the IAC valve. Your car has more that one O2 sensor. What code does the CEL return?
99 CSVT Green/Tan 13,700Km # 84 of 2760
For Sale 96 Contour GL 2.5 ATX 120,000Km K&N Air Filter Mobile 1 E1 SVT Wheels & BFG G-Force Rubber Aluminum Painted Front Grill
Posts: 1,040 |
Originally posted by SonOfABoss: ... I asked him which sensor it was, he replied my car only has 1 O2 Sensor, so I bought a Bosch O2 Sensor and replaced the one at the front of the engine (right by the access panel to the fogs) and reset the computer and went to work...... Although you didn't mention the code read I think you have replaced the wrong sensor. The more likely culprit, of the 2 that your engine has, is the one on the exhaust manifold.
Posts: 45 |
I had a similar problem. My local Ford dealer diagnosed a dirty MAF sensor which they cleaned (fixed the poor fuel economy, not running rich) and they also cleaned the IAC to level off the idle. My idle still jumps when I shift from any gear into park or neutral, the Ford tech. said that was normal on these cars("they tend to spike") Have look at your plugs, they will tell you how well your engine is running. Mine were black (rich) before the above fixes were done! Good luck.
The Ford tech also suggested I get rid of the K&N!~ I did, and replaced it with K&N conical fiter!
David BC
White '96 Mystique GS ATX - A work in progress! White '88 Cherokee - still going places!
Posts: 724 |
Everything I had done to my Contour I had done at Waynes garage up on rte 522, almost 20 minutes out of town but they are old friends and have treated me reaallll good. For exhaust issue though, there is a guy down near the bowling Alley names Mike Bane that has a shop, but I can't find his phone number, ask someone where you work they might know. Tell him Mike Walls sent you (Good name to drop) he'll probably do it for next to nothing and he does good work
Ryan
Posts: 242 |
Originally posted by SonOfABoss: Here are the problems... I know my CAT needs to be replaced (car has just under 63K miles) My cars idle jumps when I come to a stop, from about 600 to 1100 RPMs... I have poor gas mileage...And the car seems to have lost about 10-20HP... I took the car to a local Ford dealer and them run a dia. test for me... The guy told me that the O2 sensor was sticking (they don't stick, they either work or they don't) I asked him which sensor it was, he replied my car only has 1 O2 Sensor, so I bought a Bosch O2 Sensor and replaced the one at the front of the engine (right by the access panel to the fogs) and reset the computer and went to work... On my way home that night the CEL came back on and it started acting up again... What else could be bad? I'm thinking it's the EGR valve and I may need to clean my TB...The car is a 1997 GL Sport, Zetec, MTX... Thanks in advance... Jumpy idle could be a vacuum leak. Pull the fat line from the brake booster, put a bead of some silicone around it, put it back in, and let it dry overnight. I've seen this on cars other than the 'Tour.
2 Red Tours! '96 GL V6 ATX - the wifes ride '98 SVT with both options - my toy! K&N / Glove Box Light / an dats it!
Posts: 165 |
Your catalytic Converter is covered under 8/80.... So if your car has less miles on it than that Ford will pay for it.....
John 1996 Ford Contour Zetec. ~Torreador Red 5 Speed. ~17" Nocturno Rims w/205-40 series tires ~SVT Shift Knob Thanks to Eric ~Custom painted cowl, wipers, mirrors, sail panels ~Color Shifting interior highlights ~Eibach Lowering Springs. ~Pioneer C.D.Player. ~5% Tint on all windows including front window. ~Custom Black Dyed Carpet. ~Fubo Antenna In Middle of roof. ~Shortened Billet Antenna in rear. ~Indiglo BNM Gauges and ~Speedpeople Indiglo HVAC panel. ~High Flow Cat. ~Custom exhaust. ~Custom dyed Steering wheel. **Soon to come** ****Air Cylinders**** **Another TV/DVD Player ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
