I believe I have a front wheel bearing that hums and is very noticable from about 30 to 55 MPH. The noise is present when going straight and turning to the left. The noise disappears when I'm in a right hand bend. Any ideas on which side I should replace? TIA
Scott
H
H
I just took mine in for the same thing. They said one was shot and the other side was also on its way out. Not necessary to replace both but I would more than suspect that you will eventually have to do.
stock 1998 silver frost SVT E0
When you turn left the weight goes to the OUTER WHEEL of the turn...the RIGHT and vice versa...so its the right front that is noisy....
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Thanks Terry, I suspected that was how this would work out but wanted some additional input before starting the work.
Scott
Bummer... I just finished the right hand wheel bearing, strut, spring and lower balljoint and I still have the noise frown I'm planning on left strut/spring, lower balljoint in a few days, so it looks like the left wheel bearing gets replaced also... BTW- One of the local NAPA shops charged $43 for the bearing + $35 for machine shop (press) service.
Scott
