I have trouble starting my '98 Contour. It has only happened twice so far. The first time, I traveled about 30 minutes at 60-65 MPH with the A/C on and outside temperature of about 100 degrees F. The car was fine. Once I turned the car off, went into a store for 5 minutes, then came out, it wouldn't start. The engine turned over and shook (engine shook the whole car) violently for maybe 5 seconds then stalled. I tried to restart it, but nothing. I opened the fuel tank to reduce pressure in the gas tank. Still wouldn't start. After waiting 15-20 minutes, it started just like normal. The second time this happened, I drove about 30 minutes again, fan on but not A/C, outside temp at about 80 degrees F. Stopped car for 5 minutes, then started fine. Drove for 5 minutes, went into store for 20 minutes, then it started for 5 seconds, shook violently and stalled. then after 15-20 minutes, it started like normal. I thought it was heat, but the second time, it was only 80 degrees. Anyone ever had trouble with this? Any suggestions?
