Posts: 92 |
Has anyone else had the following problem and been rejected by Ford even though vehicle was built within the time frame of assembly (1994-1998) covering model years 95-98.. My 95 was built in March '95
from Transport Canda site, NHTSA has the same campaign # 98S26 ::
Make: FORD Model: CONTOUR Affected Year(s): 1995 1996 1997 1998 Units Affected: 19492 TC Recall #: 1998208 Manufacturer: Campaign Code: 98S26
Recall Details THE FLOOR SHIFT AUTOMATIC TRANSMISSION CONTROL MAY BE DAMAGED IF SUBJECTED TO CERTAIN VEHICLE INTERIOR CLEANING PRODUCTS. IF EXPOSED TO THESE PRODUCTS, THE TRANSMISSION GEAR POSITION INDICATOR MAY DETERIORATE AND NOT CORRECTLY INDICATE THE ACTUAL GEAR POSITION. IF THIS OCCURS, THE SHIFTER WILL CONTINUE TO OPERATE NORMALLY, BUT THERE IS THE POTENTIAL FOR INCORRECT GEAR SELECTION. CORRECTION: AUTOMATIC TRANSMISSION FLOOR SHIFT CONTROL WILL BE REPLACED
stock 95 LX,6cyl ATX
98.5 wheels with Yokohama AVID T4's
Posts: 606 |
I have this exact problem and I was ALSO told by Ford that no recall was applicable to my 95 Mystique. I have not dug out the old paperwork from the previous owner to see if the recall had already been done. But when Ford looked up my VIN, they told me there were no recalls applicable.
'95 'stiqueLS 2.5L ATX
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Homemade heat shield
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Blacked-out pseudo-chrome
Posts: 606 |
I haven't yet forgotten which gear I was in after downshifting/upshifting, but if I have dropped to second and then put it back to drive, I have to push on the shift selector thing until the red stripe moves from 2 up to D
S&B / CTA intake
KEM Mag-Plus wires
1/4" TH fix
Xenon bulbs
Fog light rewire
ATX cooler
Flowmaster 942042
Posts: 871 |
There was not a recall on this matter that I know of, just a TSB(Technical Service Bulletin). Ford will fix TSB related problems at no cost but only if you are still under the original factory warranty. I had that problem and had fixed while under the factory warranty. However, even recalls usually have time or mileage limitations.
Keith W
98.5 SE Sport ATX
Lt. Denim Blue
Other car
'02 3.0 Duratec Taurus wagon
Want some real political discussions? Try
www.freeconservatives.com
CEG road warrior
CEG road warrior
Posts: 17,248 |
I can't see what gear I am in....I changed my shifter got a shift boot and got rid of the shift indicator.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 92 |
Its a recall.Campaign # 98S26 which is not a TSB..check out the NHTSA site.
Posts: 1,603 |
I had this recall performed on my 98.5 SE Sport. All they did was replace the shift indicator plate.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 92 |
Ford got back to Transport Canada (= NHTSA in USA)who sent me a note to the effect Ford indicated that the GL models were only affected and not the LX models. Were the ATX shifters actually different in apperarance and size ? When all was said and done, I wonder why Ford Customer service did not tell me about the difference instead of beating around the bush.
Posts: 1,459 |
Same thing happened to my on my 95 GL. Ford wouldn't fix it. They said they couldn't find any record of it. I took a copy of the NHTSA documents to them, but they still wouldn't fix it.
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
