#64751 06/29/02 07:15 AM
I have read quite a few posts about all sorts of the MTX-75's problems (before and after you {TH} replied to my situation last week).
Background on my SVT tranny:
  • Cocktail at 10kmiles
  • Tranny has always been tough to change gears
  • Frequently (once a day or more) grinds gears when shifting (usually upshifting)
  • When left in neutral overnight, impossible to put into first until engine warms up (cold mornings) - leaving it in first overnight solves this as there is no need to shift to get moving; sencond wasn't really a problem
The shifter just went out while upshifting (not going fast or accelerating quick at all). The shifter could not engage any gear. The mechanic described it best: he just wound his hand in a circle (like a wax-on, wax-off circle) meaning that there were no gates or hinderances to moving the shifter at all. The car is now at the Ford dealer; they told me that the tranny had "disentirgated" and they had "ordered" me a new part. I found out (a week later) that the part (tranny unit) wasn't avaliable and they asked me to have it rebuilt. Having read all the horror stories about MTX-75 rebuilds, I was extremely hesitant.
I am wondering if I can get the double-mass damper and/or the Quaife LSD (wasn't this OEM on the Mondeo ST220?) installed while the tranny is getting put in. I guess what I am asking is "will they install it for me if I pay for it?". Also, can I get them to put in the cocktail solution?
BTW, Terry (Haines), what would you charge ballpark for a bulldog MTX-75 (OEM ratios) for an SVT + a Quaife? I would be looking for something to last the remainder of the car's life and I assume I will have to get a new tranny when the next one fails 31k miles from now.
Thx all
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum.
David
* 2k Black SVT on 17" Konig/Yokohama
* MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come:
19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
A Bulldog box including a Quaife costs $2100.00, a core charge of $400 is added and will be refunded upon return of your old transmission.
There are other upgradable options that can be added to the Bulldog box, such as Aeroquip fittings...basically the Bulldog box can be fitted to your needs.
HTH
Ryan
Latest Mod: Mirko Splitter
