bamf2go Offline OP
With a 2 channel amp that sends 75watts rms at 4 ohms x 2, how would you wire this tweeter and this mid-driver at 4 ohms (if you have 2 of the tweeters and 2 of the mid-drivers, 75watts to each side)? Note: the problem is that the impedance of the tweeter is 6 ohms.
1998 black Contour SVT E0 -KKM Intake -B&M Short Shifter -SPARCO front strut tower bar -24mm Aussie rear sway bar
2
The problem is not a 6 ohm tweeter... It's you need to design a passive crossover or I would use an amp or pair of channels for tweeter and midbass with active crossover.
Madisound designs or builds and a few sites will design or will instruct you on passive crossover design. Madisound (www.madisound.com) or Solen (www.solen.ca) can sell you the components to make it.
But, with both drivers at 90 dB sens, I'm sure you will find running the tweeter at 56 watts and midbass at 75 watts will not be an issue. I would not be surprized if you still have to cut the tweeter by about 3 dB to match with the midbass. Your midbass needs power but your tweeter does not and should keep up just fine.
Anthony B. Davis 2Deep2 Silver SVT 2002 IASCA SQ Ult Ama 601+ World Champion runner up 2002 SLAP dBQ Champion 2000 USAC SQ World Champion 2002 USACi SQ World Champion
bamf2go Offline OP
I already have two passive crossovers, crossover point is 2500hz. It says their is selectable attenuation for the tweeter level, but I don't know how to do it...
There is probably a switch inside of the x-overs. I'm using those tweets with some Vifa PL's and have them attenuated by -3dB to best match them to the mids. That should be a very nice sounding component system.
1999 Ford Contour SVT #900/2760 (SOLD) 2005 Mazda 6s 2003.5 Mazdaspeed Protege 1998 Ford Ranger 4x4
2
Do you know if the crossover was designed for a 6 ohm tweeter?
If not your crossover frequency may not be 2500 Hz at all.
It's possible to look at the value of the components on the crossover to know crossover type and resulting crossover point with a 6 ohm tweeter. You would need to look up a network table for the crossover type and you will know your crossover point.
If the crossover was designed for 6 ohm tweeter well you have 2500 Hz, which may be too low, but you should be able to match your tweeter to your midbass in terms of volume.
bamf2go Offline OP
Anybody have any ideas as to whether these peerless mids and vifa tweets (links above) will sound compared to the new focal access components (165A)?
bamf2go Offline OP
anybody?
Just as good is my guess
Remember this is why we're at war! I'm now officially a troll! 2004 Saturn ION QC with Sport Package AIM/AOL: animusshinigami
Moderated by  dnewma04_dup1
