ok guys it been a minute sents i have said anything in the group computer died on my just like my car seems to want to do now i have read everything everyone said to do and i have done it all the way from the plug wires(9mm ford racing), spark plugs(autolite DP), MAF cleaned,fuel filter, fuel system clean, engine flush, thermostate, and i am using 93 octane gas, but i still have major lag off the light like the car is about to die and i hit the gas now and the brake light comes on and when i hit the brake it goes off in the morning i start the car and it starts up but cuts right back off ohhh i forgot i had my timing belt changed and all the tentionors put a new valve cover gasket on to but back to what i was saying is the cut will cut off after starting then when i start it up again it will start and idle will drop like its going to die again then the idle goes up like i just hit the gas i dont know what the hell it could be i get no engine like or anything at all i am at 105000 now do yall think i may have to change the mounts and maybe the coil is going bad i dont know what the
f@##$ is going on let me know
D@#$% please ohhh and my temp indecator goes up the the normal place and then i look at it and it is at cold again then look at it and it goes back up the the he!! is going on
